Trouble on Day 2!! HELP!!!
62 UNI 4x4
Post by 62 UNI 4x4 »
So I was driving into work this morning when I noticed that my engine started losing power and would not respond to acceleration. I whipped out my phone to check my Voltage guage (no interior or dash panel lights yet) and the voltage was about 0.
I turned off my high beams, extra set of headlights, and aftermarket cooling fans, I check the Voltage guage again. It jumps up considerably!! I now can accelerate without the engine backin off on me.
HOWEVER, I get parked clock in, go back out to start it real quick. WONT START. Not turning over but it sounds like the battery is dead....??? Does this sound like a viable diagnosis. Please leave your thoughts and any ways to check.
Brian Taylor
Post by Brian Taylor »
Yes dead battery.
That is the result but you need to find the reason.
Do you have too much draw on you alternator (low amp alt)?
Do you have a bad Alternator?
Do you have a bad voltage regulator?
From the sound of it you have a lot of electric components, so get a jump start when you leave. Have you alt checked and go from there.
1966 Ford F-100 LWB 300
62 UNI 4x4
My alternator is less than 1 year old and it's 140 Amps.
I still have the old alternator but i see no need to replace the new one (unless it's bad).
Should I just get a new battery? The truck did sit for a few months before i received it.
Or should I just hook up jumper cables and let it charge from another car for a little while?
you should check all of the electrical connections for corrosion, especially the grounds.
last problem i had similar to that was the + batt cable on the starter relay being loose.
