Since I haven't shown them yet,
These are from I'm guessing 97-01 or so extended cab. When you pull up on the handle they slide and lean forward so you can put a passenger where the gas tank goes
Power lumber if I ever care to hook that up. I could use a drivers - side cover (plastic piece) if anyone has something.
Since I didn't mention it before, the transmission cover is from the 74 parts truck. No it doesn't fit but it's a good start. The way I have it, I can look under it and see the transmission so it doesn't fit the floor curve. It's also slightly too wide.
If you look in the seat picture you can almost make out my attempt at a 5 gauge panel. I didn't like the way it looked (too plain) so I'm working on molding in a 58 gauge panel. I just started on it today but thought I'd get some pics in. You'd think I had a paint scheme but sadly no.
I'm attempting to fill my filler. I'm almost finished with this just don't have any newer pics. I made a dish shape with a hammer before I installed it. If you're trying this you can actually flip it over and check it on the truck. I don't know how to explain that. You would be looking at a dent and make the sides smooth, than when you flip it over you have a dome that is the right shape.
I used the old rubber grommet as a template to make my circle. I then straightened out the hole a bit and used these headless bolts to hold it together. I'm a bad welder.
Oh and now I guess I have to say I'm painting my truck. But since it doesn't need much bodywork, it shouldn't be too hard and I can fix a few mistakes that have been bothering me.
I also found out when working the filler neck that the back of my cab had big dents like the whole bed tried to go through it. But my bed is dent free and that's obvious so I'm guessing they replaced it when the truck was fairly new. So sad, its not all original
Oh well, nothing else is original anyway.
That's all I have for tonight but just ask if you want too see pictures of anything.
