while I'm waiting for the one dude to get back to me on selling me a sending unit, I was checking my wire for voltage...
Is is normal for the sending unit wire voltage to flucuate up and down?
With the tester or my voltmeter, it's as if someone is flipping the key on and off.
Just wondered if anyone has seen this before.
Sending unit voltage
ScottRod
ScottRod Customs
'64 F-100, '66 Mustang, '05 Road King
ScottRod Customs
- Uncle Skip
Ford blue blood
Wait a tick...WHAT are choppers? The resistor thingy on the speedo?
I realize the gauges are just amp meters, but is the voltage supposed to do that or not. One says it should have a steady 4-5 volts and you say it goes up and down.
I can't find in the Chiltons where it says anything about it.
ScottRod
ScottRod Customs
ScottRod Customs
Ford blue blood
You are talking about the "voltage regulator", a rectangular shaped can about 3/4" long mounted to the back of the speedometer, has one wire in from the ingition switch, two wires out, one to the temp gauge and one to the fuel gauge.....in the older vehicles this "regulator" reduced the average voltage by "chopping" it. Points open and close (bi-metalic strip) turning on and off the voltage (current flow). Newer regulators are solid state and provide a steady regulated voltage. If you average the time closed to the time open through a load (the instruments and their senders) the gauge sees a reduced voltage (less current flow).
Bottom line, the stock voltage regulator in my 61 Uni provides a chopped voltage to the gauges and they both work like a champ.
Many great Fords,
