Greg D's Traditional Build of a 1964 F 250
Well, actually I'll just fix a few things first. I am going to start on it today so I thought a build thread was in order.
Plans are;
pull the 292 and freshen it up
reinstall with my T-5
cut it down to a short
lower it with F100 axles
will install the tires & wheels from the 62 (they need to not just be sitting there)
repaint it - no not beige
I'll will eventually do more to it but this is the list for this year. I plan to drive this truck to SS.
Here is the purchase announcement thread rather than reposting it all here.
http://fordtruk.com/forums/viewtopic.php?t=15847
Plans are;
If it is not too much trouble i would like to see some pics of the engine mounts.I am putting a y-block in my uni and plan to use car mount as opposed to the truck mounts.With the aod i am using i am worried that there will be too long of a span between mounts.Afraid it will put too much stress on bell housing area.
There are pics of the mounts in my photobucket.
Got some work done this weekend;
I adjusted the shifter linkage yesterday - it wouldn't go into 2nd consistently. That turned out to be be a waste of time the tranny is toast. I already knew it needed rebuilt cause the 1st gear sincros are gone - wasn't going to leave it in anyway.
I put some leftover from a parts truck insulators under the cab mounts to get the cab sitting right - I used stainless bolts this time.
Today I worked on the floor - the mat as cool as it was turned out to be pretty much trash so I just cut it out.
I cleaned up the passenger side first and painted it with POR 15, it's getting covered with carpet so the UV issue is - a non issue. The floor had some pretty substantial pitting but only 1 spot weld on the cab mount and the flange that attaches to the kick panel were corrupted enough to need repair - I just welded them back up with some .035 flux core. I didn't get too anal cleaning the up because they will be covered with carpet anyway.
Now for a few pics.
This is what it looked like under the mat - it was soaking wet from condensation.
After a little cleanup.
It will need a little work on the tunnel here.
After a good coat of POR.
[IMG]http://i300.photobucket.com/albums/nn38/GregDvsn
/1964%20F%20250/64055.jpg[/IMG]
Drivers side was even better. I'll have to drill out 1 screw to get that piece of trim off but at least the mat is gone so it isn't holding moisture anymore.
Now for a few pics.
Cleaned up the drivers side floor today after work.
Considering the condition of this truck it would be shame not to weld a small patch here. This right under the brake pedal where the mat was worn through.
Patch will be about the size of a business card is all. I am out of .030 flux core so I'll have to pick up a roll to do it. Seeings as I can't get it perfectly clean without digging into the metal more than I want to and and I can't get to the back side flux core is the way to go here.
I'll be a really lucky guy if this is the worst patch I ever do again, lol.
I examined it REAL close underneath - pretty much knew what I would find.
Tonight is a secondary project to this truck - swapping the fuel pump in the van so I can put the 64 in the drive. If I don't have to keep it movable so I can put it back across the street I can get alot more done.
Supposed to get a couple days of rain - I'll start getting a few things together for it for the next round.
Still working on picking colors - have a few ideas but haven't settled on one.
I was originally going to be a semi flat black with some metallic custom paint (secret, lol), see alot of cars & trucks done like that anymore - it's still on the table though. I'll need to pick something before I fix the roof - I'll want to get the color around the windshield frame before the glass goes back in so I don't have to pull it again for paint.
- Alan Mclennan
Greg D wrote:Cleaned up the drivers side floor today after work.
Greg, just as a suggestion, why don't you just clean the area up good and put a layer of Bronze weld over the area, then coat with Por 15. It`s not a structural location!, Just saying!
Robert,
the link in the first post will take you to pics of it.
Alan - Bronze weld?
Alan - Bronze weld?
i think what Alan is saying is just to take a torch and some brazing rod &
fill in the holes with brass...
then put the POR over the top and you wont even notice.
- Alan Mclennan
Pat you got it in one!, they are only small holes!, so cutting out the section some times is a bit of over kill!. I think a lot of pin holes can be over come this way, just watch the heat!
I don't have an Ox/Acetylene set up. Maybe could grab one of those small ones just for this though - I'll check into one.
I did get some cleaning & prepping done over the weekend. Got some paint I need ordered.
I also managed to pic the base color for the paint job. I have had the scheme in my head for awhile.
Been wet & rainy since Saturday so not much since then.
Next decent day the bottom of the cab starts getting POR.
I found a new similar Product at the paint store that is a much better price - $37 vs $50 a quart. If these guys carry it - it's good.
That's a pretty good idea. I could also use it as a putty to fill some of the bigger pits. After the bottom is POR'd I should have it sealed real well then.
I'm envious of those that have welders and can use 'em but what I use on small stuff like that is 3M Structural adhesive And sometimes a sheetmetal patch if needed. Gotta clean up all the metal prep as usual but it works super fast and doesn't dry glass hard, but has a slight flex feel to it. Then, you can also grind and sand it, paint it. Someday I'll try to get pics of the process.
