Ranger seats???
simonscr
Ranger seats???
Post by simonscr »
I logged on to the forum this evening and saw a few posts on the Rangers.
If I wanted to yank out my bench seat and put in the Ranger seats, is that a direct bolt in? Are the Ranger seats the same as a mustang seats, just different tracks?
Simon
65 f 100
semotrucker
Post by semotrucker »
A member here is reproducing the seat brackets(slickcollector) I believe the seats are the standard mustang buckets(not pony interior) Someone will gleefully correct me if any of this is wrong mind you.
Cam
Michelle
Post by Michelle »
Cam is absolutely correct in his comment. Indeed they are the Mustang buckets and are the standard interior seats. The seat track is also the same as the Mustang, the difference is the riser. The Mustang seat set low on the floor, the F 100's seat sat higher and has a riser attached to the seat track to raise the seat. Buy a set of risers from Slickcollector and get yourself a set of 65 66 Mustang seats and you will be in business. You will have to drill four extra holes in the floor for the inside seat tracks. The outside tracks use the same holes as the bench seat.
Michelle
simonscr
Post by simonscr »
Thanks for the education :!:
Simon
65 f 100
Casey 65
Post by Casey 65 »
When you find the seats be prepaired to rebuild them, unless they are pristine. I thought I had a nice pair, but when I removed the covers to change colors I found the frames covered with surface rust. The burlap on the springs was very rotten and the foam was in pretty good condition for a 45 year old seat. Nothing broken or rusted through, just a lot of surface rust. Sacramento Mustang will do seat covers for you in any color, including none Mustang colors for about $180.00. The company that actually does the covers is TMI, also in California. TMI will send you swatches to choose a color you like. Great to do business with. Also, be sure to get the seat tracks with the seats. These run about $56 a seat on Evilbay. The foam (called seat buns) can be found on Ebay for a good price. Many of the Mustang restoration companies sell them for a variety of prices, usually about $90 for the four you need. CJ Mustang (on the net) sells most of the special bolts, springs, etc and do not charge shipping. If you have not reupholstered a seat before this will be a real learning experience for you. Both the seat and back have two "U" shaped wires. One in the seat cover and one behind the foam and the springs. These hold the cover back in place. There are several sites on the net that have photos and instructions on how to install the seat covers and rebuild the seat tracks. However, this is a job that can be easily accomplished in your shop and will give a great deal of satisfaction when someone asks, Who did your upholstery?" and you can say, "ME!"
I learned the above because I decided I wanted a Ranger clone. Oh, also the Falcon console can be found on Ebay or Craigslist. I found mine on Craigslist in town and didn't have to pay shipping and I was able to see the console before I bought it. Also, Slickcolector on this site has the brackets for the gas tank cover used on the Ranger Package. Michelle is the source for info on the Rangers and will be glad to help you out when you have a question.
So, go for it and we expect to see your Ranger clone at Slick Stock in 88 days!! :thumright:
"One Test Result is Worth One Thousand Expert Opinions" - Werner von Braun
Hawkrod
Post by Hawkrod »
Michelle wrote:Cam is absolutely correct in his comment. Indeed they are the Mustang buckets and are the standard interior seats. The seat track is also the same as the Mustang, the difference is the riser. The Mustang seat set low on the floor, the F 100's seat sat higher and has a riser attached to the seat track to raise the seat. Buy a set of risers from Slickcollector and get yourself a set of 65 66 Mustang seats and you will be in business. You will have to drill four extra holes in the floor for the inside seat tracks. The outside tracks use the same holes as the bench seat.
Just a minor point, the seat tracks are not the same as a Mustang. You can use Mustang ones in a truck but you can't use truck ones in a Mustang. The Mustang tracks have longer threaded studs that go through the floor. On a truck the studs only go through the brackets so they are much shorter. It is basically a cosmetic issue but it makes it easy to spot fakes if they did not cut them off (and most people don't!). Hawkrod
Michelle
Post by Michelle »
Thanks for the tip Hawk, I will keep the seat stud length in mind when checking out trucks that may be faked. Also I had noticed that on my truck the studs in the seat tracks had acorn nuts on them instead if just a bare nut on them.
Michelle
ABA
Post by ABA »
What are the extra holes in the cab floor for ?
All but one of mine still has the rubber twist in plug.
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
simonscr
Post by simonscr »
Casey 65 mentioned using a falcon center console. What year of falcon am I looking for? The uncle that gave me the 65 has a 64 2 door hardtop and has had 2 parts car, may have a extra console that I could use.
Simon
65 f 100
Michelle
Post by Michelle »
simonscr wrote:Casey 65 mentioned using a falcon center console. What year of falcon am I looking for? The uncle that gave me the 65 has a 64 2 door hardtop and has had 2 parts car, may have a extra console that I could use.
You want a console out of a 64 or 65 Falcon or Comet. Please note, you will have to cut the botton of a Falcon or Comet console to fit you truck, The trucks have different cuts on the botton depending on the size transmission hump you have. Also a console from a Comet or Falcon convertible will not work as they are cut altogether different than the hard top cars.
Michelle
Michelle
Post by Michelle »
The extra four holes are for the two inside seat risers that your seats sit on.
Michelle
Thunderboy
Post by Thunderboy »
Not sure I am following this right, Michelle - Do 65-66s have holes pre-drilled in the cab floors for the inside seat brackets? You don't need to drill? I ask because I am out of town, and not near my Slicks (planning to do Mustang seats in my F250, and about to order the seat brackets from Jim) to look for myself. :?
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
simonscr
Post by simonscr »
Thanks Michelle. Your knowledge is wonderful :D
Simon
65 f 100
Michelle
Post by Michelle »
Unless your truck is an original Ranger it will not have the extra holes in the floor. It will only have the holes with nut plates for the bench seat that are located on the left and right sides of the cab floor. For the bucket seats you will need four extra holes drilled toward the center of the cab for the inside tracks of the bucket seats. The bucket seats will sit on a riser to raise them off the floor whereas in the Mustang they sit flat on the floor. Each bucket seat has four mounting bolts holding it to the floor, two for each side of the seat, Two of these holes (the ones close to the door) are already drilled and are the same ones used for the bench seat. The two holes near the center of the cab for the inside of each seat are the ones you will need to drill.
Michelle
Garbz
Post by Garbz »
Your extra holes at the back of the cab in the center with rubber plugs are for seat belts. All 61 to 66 cabs have them
Garbz
64 F100 Christine "Heartless" and Mean.
63 F100 Uni Custom, Cammer. T56 Low and fast. Still under the Knife
69 M250 Crew Cab 4x4, 472 EFI, Ranger, CC, Long bed
05 Escape.
All Ford and nutthing but Ford.....
ABA
Post by ABA »
Garbz wrote:Your extra holes at the back of the cab in the center with rubber plugs are for seat belts. All 61 to 66 cabs have them
Garbz
Ahh, ok....now I'm wondering why a CC didn't have seat belts and when did seat belts become mandatory?
'01 F150 Lightning
490RWHP
Jerry
don morris II
Post by don morris II »
Do both seats in a ranger have tracks on them or just the driver ? I have seen on early mustangs 64 1/2 passenger seat does not ajust
FORD, FAST, FLYING, FIRST, ALL START WITH F IS,NT THAT "SLICK"
Michelle
Post by Michelle »
Both seats in my truck are adjustable. I assume most are.
Michelle
Thunderboy
Thanks, Michelle and Garbz, for clearing this up for me. :)
Drew
lastwagen 66
Germany
Post by lastwagen 66 »
ABA,
Seat belts were first offered as options by Chrysler and Ford in 1955 on their 1956 models. By 1965 all US auto manufacturers were providing lap belts in front outboard positions. In 1967 National Highway Safety Board issued the initial Federal Motor Vehicle Safety Standards 208, 209, which set standards for lap and shoulder belts in front outboard positions, and lap belts in all other positions (effective January 1, 1968 and March 1967, respectively). The Federal laws applied to all manufacturers of new vehicles for sale in the US; seat belt usage laws are state laws that vary by state. I didn't know either so I looked it up. The link to FMVSS 210 (below) has seatbelt attachment/anchorage info in the back. :)
Carl
http://www.enotes.com/everyday-law-ency ... belt-usage
http://www.access.gpo.gov/nara/cfr/wais ... 71_02.html
http://stnonline.com/resources/seat-bel ... evelopment
“What we’ve got here is … failure to communicate.” The Captain, in Cool Hand Luke
‘66 F100 CC Styleside LWB 352, auto "Phoebe" SOLD 2011 - Gone but not Forgotten!
‘01 F-250 Super Duty Crew Cab, 7.3L , 2WD, SB "Crusher II" is my DD....330K and counting.... 9/08/17
