Have a great day
New carburator
New carburator
Hi everybody , I will must buy a new carburator for my truck ( V8 352 , 2V manual choke) , could you give me please some links to find the good reference ( and the best price
) ... thank you folks.
Have a great day
Have a great day
1966 F 100 shortbed
1965 hardtop mustang
FORD AND ONLY FORD
FORD AND ONLY FORD
- jkimbrel65
delete
I tried being normal once...
Did someone steal yours?
Next time someone puts a kit in one of these things could they please take some pics and make a how to.
The 2 barrel Autolite is the worlds simplest and most reliable carb ever built. A rebuild kit is somewhere around $20 and has so few parts that anyone with a can of carb cleaner can install it.
If your core is shot or you took a hammer to it just find, an old wrecking yard and pick one out of the barrel
Ok that may be a little harder in France
Sorry for the sarcasm The fact that you couldn't find what you needed in all the threads on carbs just means that a little more definitive information on these old gems in the rough needs to be put together.
Thunderboy
What Tech said. That is the simplest carb ever to rebuild, and they are pretty reliable, too. Read the instructions with the kit. If you can build a model airplane or car, you can do this carb!
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
http://www.therangerstation.com/tech_li ... 0_carb.pdf
This will tell you more than you ever wanted to know.
Tech
Tech
there is always something like this one at Summit Roc.... A lot of times a carb just isn't rebuildable and you have to buy another one. My sons on his F-250 for example... we put a rebuild kit in it and it didn't work.... It was worn out around the arms that run throught the carb... still leaked like a sift...
... In these cases, I like to think Summit is a reputable source....
http://www.summitracing.com/parts/HLY-64-5334/
Hope this helps...
Hope this helps...
