I have been looking at vent window seals the last couple of days and I'm not sure what seals I need...I know that I need the straight seal that goes right behind the vent window but I can only find one other seal and I'm not sure if it goes between the glass and the metal frame that swings open with the glass or if it is the seal that goes between the metal frame and the frame work for the vent window...I found a seal in lmc and Dennis carpenter but I'm not sure witch one it is and I need both of them...so if this makes any sense to anyone and you know where to find all three seals for the vent window then pls let me know ...
Vent window seals
- ethan_lanning
Vent window seals
http://www.supermotors.net/vehicles/reg ... 6959/57442
- slickmainer
im not looking at my vents, but I recall the straight one right behind the vent is actually part of the division bar that runs into to the door and I haven't seen that part sold separately. The curved part is sold separately but do yourself a favor and dont order the LMC rubber, go with Tom at flashbackf100s
http://fordtruk.com/forums/viewtopic.ph ... c&start=80
The above (a little was down on the linked page) should help with the rubber.
and this site helped me
http://www.supermotors.net/registry/17895/69956
--Gregg--
you can't get there from here
- ethan_lanning
Thanks for the link....I have found the rubber seal that iceman replaced in the pictures and that is the seal that I need but I also need the rubber seal that goes between the vent window glass and the metal frame that it is pressed into...if anyone has pics of it that would help but I will also contact flashbackf100s
not sure if that is repopped but it can be found from a local glass shop.ethan_lanning wrote:Thanks for the link....I have found the rubber seal that iceman replaced in the pictures and that is the seal that I need but I also need the rubber seal that goes between the vent window glass and the metal frame that it is pressed into...if anyone has pics of it that would help but I will also contact flashbackf100s
- ethan_lanning
Oh..well I'll give the glass shop a call...thanks for the help
