POR 15//A Lesson Learned
I got my first Slick and I learned a lesson about POR 15. My wife tells me to wear gloves while I work with it and I say I am ok. Well, a big gust of wind comes and takes my little tupperware container flying and like a dummy I try to catch it. I end up with quite a bit on my hands, shorts and toes. So to make a long story short I am not letting my wife knows she is right, so I steal her pumice stone/foot thing and try to get it off and it doesn't work. I call Uncle Skip, because I figure he would know how, afterall he has been a big help. Well, I guess I have to wear it for a couple of weeks. I got some off with 150 grit sand paper, anybody know some tricks...I am sure I am not the first and will not be the last...
- 66fordtrucknut
Don't feel bad, I was painting on a frame this last week while wearing shorts. I still have primer spots all over my lower legs.
- lincolnslick
shawns fords
flareside64
- rbcyouthdude
shawns fords
castruck_1964
Z-man been there done that. Other lesson I learned. If there is any por in the lip you had better have a new can to put it in if you did not follow the instructions and put plastic on top before replacing lid IT WILL NOT F@#@#$!!#ing come off.
Been there done that also. Destroyed the lid getting it off
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
460 C6
Ken
Everyone has the same horror stories. But I say this........I won't use the stuff EVER again. Did my frame and now 4 years later-no miles- it looks like crap and has come off in several spots. Never again!!!!!!!
Tim
Tim
The PO did my fairlane engine compartment.
He sanded it and prepped it as directed. It peeled off in sheets. A hideous mess.
I used it on my pitted Torino roof. I had a run I tried to knife off. It peeled a 3"x1/2" strip off. This was on a rusty areas that was cleaned with marine clean, treated with the prep and then painted.
Not sure what I'll do on my uni. Maybe bedliner material.
Someday I'll get another slick
- Johnny Canuck
That is the direct opposite of my experience with the stuff.
painted my frame with it, the truck sat as a frame for 2 years while i dicked with the various schiesters (body men) who worked on my truck.
Used that POR'ed frame as an anvil more than a half dozen times, couldn't even scratch the POR. good shctuff that is. Takes a liking keeps on ticking. If you pounded on powdercoat the way I did, it would have fallen off there like glass.
shawns fords
as with any metal coating product you need to make sure the surface is properly prepared, I did my front axel with por15 and cant even remove the product with a grinder unless i plan on gumming up the grinder wheel. as well brake fluid will eat away at any paint. if your worried about por15 look up KBS coatings they also have restoration products
