generator to alterntor ?
ezernut9mm
Sweden
Post by ezernut9mm »
so, how do i wire from the stock generator to an early eighties alternator? or a one wire alternator for that matter?
i'm hoping to not hack the factory wiring too much in this conversion.
thanks/
64crew4x4
Post by 64crew4x4 »
I just did this on my 61 4x4....
I found a mid 70's truck Alternator under the hood of a 62 truck in the J/y...
I didn't have to hack any of the 61 at all...
I will take pics if you like.....
send me a pm with your e-mail....
I'll take pics today....
Stable of Trucks.....
61 3/4 ton 4x4..312v8,4speed Daily driver.
64 1/2ton C.C. 292v8,3sp,...???? 82k orig.miles
65 1/2ton flareside parts truck
64 1/2ton Flareside currently 4x4.going to be 472 powered Gasser
65 SuperCab/Crewcab Cummins 1 ton Duelly Hi-Boy Project
DukeRoche
Post by DukeRoche »
If your taking pics of the process post them in the hints and tricks forumn...be a nice reference later on down the road
The Green Machine
GO ARMY, BEAT NAVY!
tomrooster
Post by tomrooster »
Google it and you will get a lot of sites that will tell you how to do it
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
62galxe
Post by 62galxe »
Chris I used a alternator, harness and regulator out of a torino. I found wiring diagrams online.
1963 uni PATINA BLUE
1965 short bed
truckster
Post by truckster »
lol! at first i just looked at the pics and saw the wire nuts then decided to read it. otherwise it would've been open season on the WIRE NUT!
62galxe
Post by 62galxe »
I was in a big hurry getting it ready for slickstock IV. :oops: Now that I drive it a lot not much has been getting done to it.
1965 short bed
62galxe wrote: :oops: Now that I drive it a lot not much has been getting done to it.
Since wire nuts are designed for 120 & 220 volts I don't think 9 & 12 volt circuits are going to bother them much.
ezernut9mm
Sweden
thanks for the voltage reg pics kenny. that was something else i was wondering about.
Chris,
if you use a 1 wire you can run a wire directly to the battery side of the solenoid switch and just box up your original charging harness untouched for posterity.
Yep, I run 1 wire alts on all my old stuff and the voltage reg and wiring harness setup have been gone for a long time.
Greg, sure is a lot simpler isn't it. Once I discovered how easy it was to replace the old stuff I never went back. TR
Rest in Peace Cam
65 F100 Flatbed
64 F100 Short Styleside
63 F100 Short Wrongbed
61 Shortbed Uni Parts Truck
  • May Angels Fly With You
    Where Ever You Roam
    And Guide You Back Safely
    To Family And Home.
ezernut9mm
Sweden
i'm liking the 1 wire idea even better now. thanks guys.
doc6368
Post by doc6368 »
The first thing I did on my truck was replace the generator with a one wire alternator. simple to do, can be switched back anytime (I don't know why anyone would but it can be done)
This 61 Uni I had about 18 years ago was the first one I replaced the generator with a one wire alternator.
All the lights got brighter, the turn signals and wipers worked better, and the heater motor blew harder than
the old generator ever did on it's best day.
I think the gens only put out around 25 amps versus the Alternators 60 amps.
Kept the battery charged up a lot better, too.
Wish I had this one back. If any of you spot a big window Uni around the KC area,
check and see if it has the stake pockets welded up.
I had done both of them on one side but sold it before I got the other side done.
May still be like that, I don't know. Wish I still had it. TR
Rest in Peace Cam
65 F100 Flatbed
    Where Ever You Roam
    To Family And Home.
Gary Seymour
Post by Gary Seymour »
My '62 was running with a GM (I think) one wire alternator, and I will use it with the 351C swap.
Anyone running the one-wire have the charge indicator light on the dash working?
I have a factory ammeter too. Anyone know for sure how this can be used with the one-wire alternator?
The meter was not hooked up when the truck was running with the 292.
