We finally got the 1" of grit and grease off the engine and transmission, and we found this code on the transmission, which is a 4-speed on the floor with the "underdrive" first gear:
T18-1
W.G. DIV
This doesn't match anything on the site's VIN decoder, and we've long since realized that there have been a number of swaps on the vehicle--rear axle, discs up front--so the data tag, even if original, isn't giving pertinent info.
Also could somebody suggest other spots to look for the VIN on the body? These doors probably aren't original, either.
Thanks.
Cerberus
Transmission code
Transmission code
Cerberus
1966 I-Six / 4-speed
I remember seeing a VIN # stamped in my 66 frame rail. Drivers side front if I remember correctly.
The Trans sounds like its a Borg Warner T !8. should be from a later truck.
Mine has a T 18 from a 79 model.
Just out of curiosity do you have trouble finding 3rd gear? That seems to be a common problem with them.
Theres a detent pin on the reverse shift fork that has a spring that breaks and lets the shift shaft catch the reverse fork when going to 3rd.
Just thought I would include this info in case yours is doing this yet.
Transmission code
Thanks for the pointers. Could be the brakes and rear axle came from the same truck as this tranny, I suppose. The 4-speed seems a good match for the Dana limited slip rear anyway. The 240 engine is the weak link, even if I have been urged to maintain the originality of the straight six. Don't get me wrong: I like the Six, but the rest of the drivetrain can handle just a bit more.
In fact third gear does give a little grief. The whole thing is a bit sloppy, but I didn't think I was *that* bad at shifting. Reminds me of the first tranny in my '62 Econoline: I couldn't shift that thing from first to second without a grind but maybe one time out of four. Figured I was flat-out incompetent, until I found out there were no synchronizers from first to second and the transmission was affectionately known as a "crash box." Put a '64 transmission in there and never had it so good.
I'll check that frame rail. Thanks.
Cerberus
Cerberus
Cerberus
240-300, basically the same engine, 300 has a longer stroke. The T-18? granny tranny I have has a 3rd gear issue too, goes in fine slips out when you back off of the gas and torque load reverses. I just refer to it as a "semi" automatic, lol.
was "Transmission code" now Model Code
OK, I found it after some sanding and cleaning, and amazingly it matches the VIN on the door tag. So the engine is the original one, or a same-year-and-displacement replacement, while the front brakes, tranny, and axle have been swapped out.
How 'bout one last question: The model code on the door tag says 281, which doesn't match a code on FordTruk's decoder. There it's either 81A (standard cab) or 81B (custom cab). To which does 281 correspond? There are Custom Cab inserts on the door handles, but when I pulled them off, it looked as if the paint had faded differently under them than around the handle itself. Additionally this truck appears about as bare-bones as possible--one circular gauge in the dash (no bright trim), basic driveline and engine, no armrests, no passenger's visor, and the headliner's not perforated. The seats have a woven pattern stamped into (what's left of) the vinyl. On the other hand, aside from the Custom Cab door logos, it has lighter and the separate heat/temp controls under the dash for the heater, which I've read is for the deluxe version only. Knowledge won't change what I've got, but I am curious and enjoy the history side of restoration, too.
Cerberus
Cerberus
Cerberus
