NO OIL IN THE TOP OF THE MOTOR. HELP!!!
A FRIEND IS WORKING ON A 64 WITH A 223 STRAIGHT SIX. THE MOTOR IS A FRESH REBUILD . HE HAS PLENTY OF PRESSURE IN THE CRANKCASE,BUT WHEN YOU REMOVE THE VALVE COVER THERE IS NO OIL. THE MOTOR WAS ALREADY ASSEMBLED WHEN HE GOT IT. HAS ALL RECIEPTS OF REBUILD FROM PREVIOUS OWNER. DOES ANYONE HAVE ANY SUGGESTIONS TO HELP US WITH THIS PROBLEM. THANKS
There should be 2 tubes in the top of the rocker shaft that curve down into holes in the cylinder head. These are the oil feed for the valve train, are they in place? Are they plugged?
The front tube on the rocker shaft is a drainback. The rear tube should have pressure from below. If you don't have pressure to the rear tube, the # 3 camshaft bearing was prolly put in without lining up the feed hole. I would suggest to pull the cam and check before any damage, if not already done.
Fred
Fred
eng
hey I had the same problem,, turns out hedauls did not put the cam bearing in properly,, youd better fix her,, I lost my rockers, bent a pushrod, and the rocker shaft was shot to hell,,
the boys at headauls went as far as to say they did'nt assemble my motor
that was the first time I was I talked to a bold face lier, but on a happy note they replaced all mentioned above, down to the gaskets, My buddy fixed her up and she rums like a gem!!! just like fmartin said,, that'll cure you lube needs
Is there a bearing with a groove in the wrong position in the block? Maybe just got a wrong bearing in the set?
Had a similar problem with my 390 a few years back. Installed a different cam, fired it up and no oil pressure!
Turned out to be the distributor was not seated onto the oil pump drive shaft. My engine ran for over an hour with no oil coming to the heads at all! The engine was running perfectly fine too. Might want to check and see if the drive is fully engaged in the dristributor.
Moose
Moose
American born, German blood, Texan attitude..... And people wonder why they call me "Moose."
66 F-100 Too much to list
05 F250 The Tank
05 F250 The Tank
How bout this.
Headgasket installed upside down. Does it overheat at all?
If it was flipped the water jackets may line up but not the oil galleries
Just a thought
At least I think it was a thought, at my age you really cant tell any more!
Dave
Just a thought
Dave
From a guy without his Ford that he left on a rock in the North Atlantic.
