Brake Cylinders for a 62- These look wrong
I scored these at Autozone
Are they right? Their computer gave these as spec.
They are two piston VS what I have. Single.
I need my junk to stop and I can't swing the disk stuff now.
If these are wrong I'll bite the bullet and get it together with disks I think. I just can't spare the addl $100 and the wait for parts right now.
Someday I'll get another slick
Garbz wrote:You have a very late production 62... Those are the infamous "63" single push cyls.
NO one makes them in repop or rebuilt.
Use the correct 62 ones auto zone gave you and add parts to convert to the double type cyl.
Garbz
Thanks!
They don't come with the pusher pins.
If my Fairlane ones will swap in I may try em.
What parts do I add?
Shoes and stuff?
I'm still debating the disk conversion. I ordered the pltes.
Phil, I still have all the backing plates etc. off my 62. Wheel cylinders are shot but these take the regular double piston type wheel cylinders.
Hauler --you are good to go eeeeer stop!
Grab 2 of your Fairlane pins and put it all back together. Thats what I did on my 63. Everything went together fine.
Those single sided things are JUST WRONG, I say!
Tim
Tim
Fanatic wrote:Hauler --you are good to go eeeeer stop!
Tim
yeah I bit the bullet and bought all the disk crap.
I figure this thing could use 1 safe componenent.
In 3 weeks or so I should have it all to swap in.
I actually said rebuild kits but what is actually done is you take the old piston ,and rubber seal and cover in and match them up, they are individual pieces and standard sizes, all you need is a good part store that knows what they are doing, and almost every time the size is on the piston and the boots
Thanks Guys!
I pretty much decided to do the swap Greg did.
I have a 3 week wait or so on parts. I have almost everything now except the Master cylinder.
I also bought upper and lower front leaf bushings from NAPA.
Luckily I took in the part numbers from the web. When I told the guy what I wanted by app he was like "nope out of production"
I threw down my numbers and he still sandbagged saying they would take a week to get. I ordered them at $10 each or so.
I think I shorted myself 4. I ordered 2 upper and 2 lower but got none for the back of the spring. Ill get em later and swap em then.
