Spare Mount setup
sully5
Spare Mount setup
Post by sully5 »
Wanted the spare under the bed and wanted to to be easy to drop.
Started by going to Pull-a-Part in Nashville. Found a spare tire "reel" in an S-10 that had the bed removed. Then I built a crossmember for it.
After removing original spare mounting bar, I anstalled this one in between the rails.
Drilled below the tailgate with a 5/8" lining up the hole with the reel.
Made a shaft that will use my lug wrench to turn it.
And . . . . it's mounted.
If thou bleedest not, thou workest not. - Hezekiah 2:12
charliemccraney
Re: Spare Mount setup
Post by charliemccraney »
That is slick. I thought about doing that a long time ago. Never did and now there is a fuel tank in the way.
Lawrenceville, Ga
1961 F100 Unibody
