3spd trans trouble
3spd trans trouble
Hey fellas! It's been quite a while since I've been around the site. New format looks good!
The truck's been running great since I finished the rebuild last year. In fact, it's back in daily driver service (the Jetta finally crapped out).
I started noticing some symptoms from trans in the last week. The 'whine' of reverse has changed and gotten louder and it's been jumping out of third gear when I transition from power to coasting.
Anyone know of a good parts kit source and/or a good tutorial on the Ford 3spds?
Since I have to drive it every day, I guess I'll be looking for a good core to rebuild.
William in LA (Lower Alabama)
1966 F100 SB - 352/3spd
1965 F100 SB CC - sold
1966 F100 SB CC - sold
1966 F250 Work body - sold
1967 F100 SB CC - 360/C6 - sold
1971 F100 Long Flareside - 390/4spd - sold
1972 F100 XLT Ranger - 360/C6 - Gramp's old truck
Plus '53 CJ3B, '54 CJ3B, '67 CJ5, '70 Jeepster, '71 Jeepster
Re: 3spd trans trouble
Might just be out of lube?
I wish it were that easy. Lube is good. Though, it is leaking out the front seal now.
I have a straight 3 speed from behind a 66 352 on Craigslist right now for $40. (Roanoke Va. You coming my way anytime soon?)
Big Bad Dad
If it needs sayin', Say it!
These transmissions are pretty common.. I'd just grab another and go for it..
make sure its from a 65-up 2wd truckfoodstick wrote:These transmissions are pretty common.. I'd just grab another and go for it..
the earlier ones and the 65/66 4x4 have a different input shaft
also there are some with a slip yoke and some with a bolt on yoke on the rear.
I've found out about the differences already. The only thing I can find around here is completely worn out, has a bolt on yoke and is apparently worth its weight in gold.
I need one with a slip yoke.
Hopefully I will find one between here and north AL. I'm planning a trip up there in a couple weeks.
- jkimbrel65
I have a few lying around.Where in N al are you going?
Mike
Mike
I tried being normal once...
Athens!jkimbrel65 wrote:I have a few lying around.Where in N al are you going?
Mike
- jkimbrel65
we will be there too
Got room for a tranny going back?
Mike
Mike
fire truck
If you don't get one, I'll bring you one on my monthly journey to pcola.....
...even if my wife has to hold it in her lap! Sent you a PM. We'll be in Athens Friday.jkimbrel65 wrote:we will be there tooGot room for a tranny going back?
Mike
TJ, it's been a while! We still need to meet up sometime.fire truck wrote:IIf you don't get one, I'll bring you one on my monthly journey to pcola.....
Thanks for the offer. Roanoke is a bit of drive. You never know, though, seems like I'm always on the road.BigBadDad wrote:I have a straight 3 speed from behind a 66 352 on Craigslist right now for $40. (Roanoke Va. You coming my way anytime soon?)
Met up with 'jkimbrel65' on Saturday. I hope those you who haven't met him get the chance sometime. Nice fella... plus his truck is absolutely cherry!
Mike set me up with a good trans for my slick! Thanks again Mike!
- jkimbrel65
Glad to help Matthew.Was good meeting you.
Mike
Mike
fire truck
Did it come with Gatorade?
clutch and power train locally in Pcola has a rebuild kit or should have. Also they can rebuild it if you dont feel like fooling with it. give em a call. We (our old late model mustang shop) did a lot of business with Jesse in Mobile, they also have one in spanish fort al i belive.
good luck
good luck
