Radiator spacers
MeZapU
Radiator spacers
Post by MeZapU »
Ever since I got my truck, I couldn't determine if these 1" radiator spacers/stand-off's were original or not. It's missing one as the previous owner just had two big nuts taking up the gap. Don't know if I should find another spacer or pull them off. The bolts are not ford. Does anyone have any insight?
Still working out the wiring and more clean up/detailing.
Black 1985 GT
Yellow 1973 Mustang Mach 1
Black 2012 5.0 GT, 6-speed, Brembo brakes, 3.73's
Wimbledon White 1966 F-100 Shortbed, Styleside, 390, Tremec 3550, Fitech EFI
bmcgc
Re: Radiator spacers
Post by bmcgc »
I do not believe the spacers are oem.
I would only use them if necessary, you want as much air passing through the radiator as possible.
Very nice looking, lots of hours invested in there.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
MadMaxetc
Post by MadMaxetc »
You want the fan about 1" - 1.5" away from the rad core. So it looks like the prev owner did the right thing. I would keep them.
My Build Thread
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
Original Truck, DID NOT Have those spacers,, have seen many of that set ups on 73-79 trucks,, It's just a trick to get the radiator closer to engine for better cooling if your having cooling issues many cooling issues are directed to rad problems,, overboring a engine is one, bottom hose collapsing, sorry fan blade, loose belt, bad water pump, bad or no thermostat, if it's a Fe, and heads been shaved you better have shaved intake in not intake gaskets not aligned,, fan shroud will help
12649
William-in-St George
I use spacers like those pictured to get a little clearance for the AC evaporator.
William-in-St. George
frdnut
Post by frdnut »
bmcgc wrote:I do not believe the spacers are oem.<BR sab="241"><BR sab="242">I would only use them if necessary, you want as much air passing through the radiator as possible.<BR sab="243"><BR sab="244">Very nice looking, lots of hours invested in there.
+1.....If it cools fine as is I wouldn't worry about it..If you are having troubles at speed I would try to get the rad sealed to the rad cradle better.
1965 F100(the wifes)
1968 Mustang 408W stroker
