radio speaker & carpet
- Marty in PA
Re: radio speaker & carpet
not that I've experienced from the factory AM radio nor the AM/FM I'm using now.
Marty
1965 F100 Short Bed w/390 and 4 on the floor.
When half of the people get the idea that they do not have to work because the other half is going to take care of them, and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for, that is the beginning of the end of any nation.
SLICKCOLLECTOR
i just about have the interior together. quite a journey and very frustrating.
jim
jim
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
are you hooking up an antenna and using the radios antenna trimmer adjustment screw while bench testing the radios?SLICKCOLLECTOR wrote:does the mismatched ohm's issue cause the factory radios to hum. every radio i try has the humming issue when bench testing them. thanks.
jim
SLICKCOLLECTOR
when i was testing the last radio i saw that little bolt and turned it and discovered its function. it got a little better but still a long ways from a radio that i would listen to. i have tried different antennas also but still the radios still are not very good. am radio is just not very good anymore. i don't like sports radio so i really don't care but i like everything to work. trimmer adjustment screw . so that's what that thing is called. thanks.
jim
jim
