had several questions on how to change the 2 indicators in the metal panel to the 1 in the plastic panel.
(or the reverse)
it is very simple here is the factory wiring
take the 2 indicator lights out and plug in the one bulb socket
turn indicator- metal vs. plastic instrument panel
- ezernut9mm
interesting. i suppose it's the opposite to run the round speedo then.
- ezernut9mm
excellent. thanks.
any ideas on what to use to "isolate" the turn signal bulbs and high beam bulb? as in, the factory had some small pieces of cardboard tubing between the bulbs and lenses so the lights didn't "bleed" into the gauges.
knowwhatimsayingvern?
Re: turn indicator- metal vs. plastic instrument panel
THANKS.
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
