5 speed for a straight 6
frank66
Post by frank66 »
I would like to put a 5 speed behind my 300. It seems like the two obvious choices would be a M5OD or ZF S5. Has anyone here used one of these? Is there another good option I should look at? I am leaning towards the ZF because it seems a little more heavy duty.
M5OD-R2 ratios
1 - 3.91
2 - 2.24
3 - 1.49
4 - 1.00
5 - 0.80
R - 3.39
ZF S5-42 ratios
1 - 5.72
2 - 2.94
3 - 1.61
4 - 1.00
5 - 0.76
R - 5.24
Blackwaterforge
Re: 5 speed for a straight 6
Post by Blackwaterforge »
I had a ZF in a 88 F-350 with a 300 6 cylinder.
250,000 miles I never had a issue.
Had a ZF in a 95 F-350 7.3.
400,000 miles never a issue with the transmission.
I had to replace the slave cylinder twice.
Depends on what you use the truck for.
Driver/light towing up to around 3000 lbs - M5OD is more than sufficient.
These were used in gas F 250s also BTW.
I don't remember which is which but the R1 & R2 look similar - one is for Rangers.
If you have some huge 8000 lb 5 th wheel you wanna drag use the ZF.
But then if you are hauling that grab a diesel engine while you are at it.
frank66
Post by frank66 »
I will be hauling / towing about 3500 pounds weekly. And I like to enjoy an occasional burn out. :steering: I would like the lower first and reverse gears of the ZF for manuvering my trailer around. After a quick search on craigslist, there seems to be more ZF's than M5's available and they are going for about the same price.
64 f100
Post by 64 f100 »
Burn outs? With any modern transmission and aluminum housings, you may be asking for problems. Just remmember these are used transmissions your talking aobut.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
