64 Tweety Bird
- Uncle Skip
Re: 64 Tweety Bird
You already know it was one step forward and two steps back on the under dash control panel so today we actually finished up the entire thing and got it mounted permanently. Couldn't resist putting in the instrument cluster just to see how it was going to match up.
For having a couple of old fat guys working on it, I think it looks pretty good.
Now that all this interior control stuff is finally finished, we can actually get started on the wiring. The passenger vent ducting was a close fit, but it hooked up perfectly.
You can see where we swapped the A/C controls with the radio face plate.
The passenger vent will be located here.
And finally, the instrument panel in place to compare the overall look of the interior.
Re: 64 Tweety Bird
Really looks neat, good work!
Re: 64 Tweety Bird
This project just keeps getting better and better all the time.
I see a new interior coming along pretty soon.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
- Uncle Skip
Re: 64 Tweety Bird
Anyway, here's a shot of Daryl's progress on the hood. He wants to finish it so he can clear up work space in the shop.
- Uncle Skip
Re: 64 Tweety Bird
Apparently I lost all the images of the build when I organized the pictures into a separate photo album. Should I start a new thread and re-post the pictures? Seems like that would be the easiest way to put the pictures back so people can see this progress. What do you think?
Yes.... I'm a dumb ass
Re: 64 Tweety Bird
Unc you could always just go through this thread and repost the pics you have the power to edit your posts . While your at it repost your tank install in the hints and tricks section several new members have been asking and we cant point them to the thread cause it aint there .
- Uncle Skip
Re: 64 Tweety Bird
OK, I re-posted the pictures. Thanks Rick.
Sorry for the brain fart everybody.
Re: 64 Tweety Bird
LOL does it feel like youve been here half the afternoon posting and yet nothing seems any differant . The truck is looking great by the way . I am getting rained out again at the moment dangit I only have 3 days to get my chassis ready .
Re: 64 Tweety Bird
Sanding and glazing and more sanding on the hood on the 4th. Now that is what america is about. Working on a classic truck.
Thanks in advance
DADwood
DADwood
Re: 64 Tweety Bird
This weekend the top of the hood won the battle. I have had nothing trouble with the top of the hood and even had to sand down to metal in a couple of spots. The battle continues again.
Thanks in advance
DADwood
DADwood
- Uncle Skip
Re: 64 Tweety Bird
Well Daryl, sometimes you eat the bear, sometimes the bear eats you. Just keep on doing what you're doing and you'll get it right. I have no doubts about you getting it right.
- Uncle Skip
Re: 64 Tweety Bird
Tweety update.
More grunt work and nothing to take a picture of right now. Daryl is still struggling with the hood and his regular work.
When he (if he) gets the hood like he want's it, I think we'll start the wiring and try to get that out of the way.
I did score him a brand new, short set of air over shocks at the Conroe swap meet for $50.00 for the rear of the truck. And we're going to try to use the front shock towers for the rear shock mounts.
Can't wait to see how that turns out.
Updates as they occur.
- Uncle Skip
Re: 64 Tweety Bird
Finally, more actual progress. Daryl just sent me these pictures of the finished hood. I advised him not to buff it until after we're ready to do the final assembly.
Dead solid smooth and I'm liking that yellow paint more every day.
Maybe we can get the pinstriper to do his hood and tail gate at the same time I get mine done.
- Uncle Skip
Re: 64 Tweety Bird
Back to the work accomplished but no photos mode.
Started the wiring with the EZ-wire kit today.
1. Nice quality and the wires are clearly marked.
2. Directions suck. Er ah, that is, they don't show you anything about where things go.
3. the wires "are" bundled in sections.
a. under hood
b. rear of vehicle
c. under dash
e. etc......................
4. Even if the wires are labeled, some of them don't make much sense. I have one labeled fan -fan. I can only assume this one takes power to the radiator fan solenoid. If anyone knows for sure, let me know.
And I'm still trying to figure out the connections to the Gen II Vintage Air unit and the controls. I think I got it, but the key words are "I think".
I want to go on record that EZ-wire is NOT the only wiring kit with sucky instructions. They're all like this.
*Attention all you manufacturers and providers, I'm available to do a technical writeup at a modest price. God knows, you all need it.
FYI
I labeled each wire by section with a piece of tape printed with what the wire says. I'm freaking old and I need a magnifying glass to read the labels. Take a little time and tag the wires now. Its going to save a lot of time later.
Next, we decided how we wanted to run the wires to hide them as much as possible.
Using existing holes in the firewall and rubber grommets we ran the dedicated wires to each side of the truck inside the firewall to limit their exposure in the engine compartment.
We are using the original headlight wires to control the new relay headlights and those will be mounted on the drivers side on the core support on a special aluminum panel I made. All the wires going to the rear of the truck now exit the drain hole inside the cab floor under the seat (thru a sealed with a grommet) and to the rear inside the frame channel.
The motor control wires (coil, tach wire, temp and oil pressure senders and compressor wire et al are also on the drivers side.
The starter wire, alternator feed wire, (those F*ing fan/ fan wires I'm still not sure of) etc are all on the passenger side. All these wires are secured to the big #10 A/C line for support with plastic wire ties.
We ran the wires for the power antenna feed and the dome and map lights up the A and B pillars on the drivers side and routed the main power wire to the fuse block inside the firewall.
Sound complicated?
Not really, just a little more involved because even though it's going to be a serious driver, Tweety is "kind of a show car" and we want to keep everything clean, simple and hidden as possible. I'll take some photos next week and maybe it will start to make a little more sense.
All the wires are hanging loose pending our final decisions as to wire locations and attachment points but all the wires are not in the general section of the truck where they'll terminate.
I'll try to document what goes where and why so maybe this can help someone else down the road.
Er ah....... I taut I taw a puddy tat.
Ciao, y'all.
a. under hood
b. rear of vehicle
c. under dash
FYI
Sound complicated?
Ciao, y'all.
- Uncle Skip
Re: 64 Tweety Bird
More progress.
I think you've all seen the rear cab cover I made for behind the seats. Well, you have to weld in some flat stock for the upholstery board to attach to and that's what Daryl just did. In addition, we planned on having a support for the amp and sub woofer to mount to behind the seats too, so he put in a couple of flat stock supports to hold the amp.
I think we're going to mount the woofer where the amp is now and move the amp up on top of the woofer.
The vertical supports for the upholstery board
The amp mounted to the supports. When the panel is installed we'll put the amp on top of it like I did mine.........
Anyway, he's still digging.
- Uncle Skip
Re: 64 Tweety Bird
Got started in earnest with the wiring today, A/C power hooked up, wiper motor switch installed, and the ignition switch in. The original light switch change over to the EZ wire harness is causing me to have gas. Can't decipher the Ford to GM scheme. Any suggestions would be appreciated.
The big issue is the shocks on the lowered rear end. I need a shock that has about a 15" OAL and a 7" compression/ extension.
Here are photos of what we have to work with. I can gain about 1" with the original upper shock mounts by rotating them up but I can't go much above the frame because of interference with the bottom of the bed wood. I'm open to most anything here.
Help me out.
Help me out.
Re: 64 Tweety Bird
Have you been on the shock manufacturer websites? They should have all of the specs for their shocks and you should be able to find what you need. It might take a while to search for it but the answer should be there.
Kevin
Kevin
kstones63
63 F100
63 F100
Re: 64 Tweety Bird
Call these guys
http://www.doetsch-shocks.com/contact.asp
Also, if you need a pin out diagram of the headlight switch I
Think I may still have a diagram
- Uncle Skip
Re: 64 Tweety Bird
Loosrp.
If you have the pin diagram, I'd appreciate it. I want to compare it with what I traced out to see if I'm even close to being on track.
Thanks.
And I'll be calling Doescth.
Thanks.
