I figured out that the sleeve out of a 3/8 inch compression union will fit inside the horn ring contact tube, if you ream it out a bit first. Mine was broken off and the contact wasn't staying pointed up and down and was grounding out on the steering wheel. Be sure to knock it in far enough that it does not ground out on the steering wheel.
easy repair for horn ring contact tube
- bobenhotep
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
Re: easy repair for horn ring contact tube
Sweet thanx. Fixing that sleeve was on my to do list.
- Limestone66
Good idea on that. This is also on my 'to do list' {seems like it never quits}, and finally install my horn ring and related parts instead of using the washer fluid button for my temporary horn.
Long live the 352
........Ron..........
1966 Ford F250 Custom Cab {Longbox}
1996 Toyota Camry {Wifes ride}
1940 Harley Davidson knucklehead {Retired in 2006, gave to one of my sons in 2010}
1975 Harley Davidson XLH {Groundpounder}
2005 Harley Davidson Deluxe {Nostalgia} Almost home 'girl'
In memory of Donald G. Roswell- My freind and 'brother'.
- bobenhotep
If someone else does this, post and let us know how it worked for you.
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
I have bought 3 new contacts thru lmc, for my 64 truck and I still can't seem to get it to work.... Every time I install the steering the wheel it appears to bend the spring and when I turn the wheel it will sound the horn when it wants too. I finally gave up and put a horn button below my dash. But maybe I will give this a try now.. Good Idea thanks
- bobenhotep
I got a turn signal setup from them with the horn contact in it. I put a washer on the screw next to the contact tube with the edge bent in such a way that it keeps the tube pointing the right way. It would fold inward and do what you are describing. I will have to take the steering wheel off but I can show you what I am talking about.
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
