The water pump on the '65 300 6 in my truck was not leaking, but I noticed some slop in the bearing the other day when changing the alternator. Since the truck sat for 30 years with an open cooling system, I figured it should be replaced. I got one from local auto parts store. The hub height is wrong, it is about and inch taller and the hub size is too large. Looking for a correct part number to use or other ideas? All listings I can find don't look right. The part number on the pump that came off is PH 284.
1965 300 Water Pump
- bobenhotep
Re: 1965 300 Water Pump
They have both the long nose and short nose pumps on rockauto.com. If you have to, get the alternator bracket off of a later model to go with the water pump. Do you have a picture of the water pump?
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
- Blackwaterforge
Ask for a pump for a truck with manual steering no ac.
I had to switch to the longer pump when I added air conditioning.
- daleshotrodshop
You were sold an early pump 57-63. You need a NAPA 42057 pump 39.99 this is a new pump not reman.
\For a picture of it click on the url
http://s7d9.scene7.com/s7/zoom/flasht_z ... any/670094]
If we learn from our mistakes I should be Einstein by now.
Impossible, 240/300 introduced in 1965.daleshotrodshop wrote:You were sold an early pump 57-63.
Ask for a 1965/71 Galaxie/LTD 240 waterpump, it's the same puppy as 1965/72 F100/350 240/300: D2AZ-8501-A replaced C5AZ-8501-A
