"Radio Or No Radio?"
Shadow
Post by Shadow »
With The Hole In The Dash Finally Patched It Looks So Good I Can't Bring Myself To Drill It For The Stock Radio I Have. It Sure Looks Like A Blank Canvas For Some Pinstriping. Any Opinions, What Do You Guys Think Radio Or No Radio?? I'm Marinating On This One At Least Overnight. :lol: Image
bobenhotep
Re: "Radio Or No Radio?"
Post by bobenhotep »
mine has the requisite "kraco hole" in the dash from a sawzall back in the 80s.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
Same dilemma, Dana; I like the look so well I considered extending the glove box to eliminate the ashtray. I then realized it would interfere with the under-dash a/c, so I just covered it with Slickstock and other car meet thingies! I may try to turn the useless ashtray into a glide-out cup-holder. The old am doesn't offer much entertainment value, so it will probably not get installed.
Hunter's 64
Post by Hunter's 64 »
http://www.classiccarstereos.com/produc ... ystem.html
hide the box , hide the controlls .pin stripe the canvas and have great sound with no visable head unit. :2cents:
Danny
CHICOF100
Post by CHICOF100 »
I have a clean and smooth dash. No Radio holes, no ash tray, no glove box. I wouldn't start drilling on my dash for nothing. My sound system will be hidden when all is done. I'm working on a custom center console, but even then you won't see my system or speakers. You might see my 8-track player, that depends on how the console comes out, you won't see my system.
milomilo
Post by milomilo »
I have the original AM radio in my 64, but like others have said, it lacks for entertainment value. I listen mostly to oldies on FM. Looking for a same hole pattern AM/FM to replace it with. If I can't find the same hole pattern, I think I will put one in the glove box. I do not change channels much so it would not be inconvenient to have it in the glove box. That would save me buy the glove box line since mine is gone.
64 F100 4X4 Styleside Wrong Bed
on a 74 chassis, 390, C6
A work in progress
Post by Gritsngumbo »
Personally like the "uncut" version, or at the very least an original AM style radio with the more uptodate "innards" and controls cleverly hidden.
bobenhotep
don't drill it, undrilling holes is a lot harder than drilling them.
"The Iron Rhino"
-duraspark II/ HEI
GJ1963
Post by GJ1963 »
Leave it undrilled! Looks great.
lucky23
Post by lucky23 »
Looks great! But I like the look of those old stock radios...
1966 F250/352/cruiseomatic tranny/Dana 60 4.10
aarons428
Germany
Post by aarons428 »
Put a radio in it but HIDE it !!!!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
graybeard
Post by graybeard »
I for one think you should save that space for a outlet on your new Vintage Air AC unit. However you need some good tunes now and then, maybe you could get one of those cool fiberglass headliners with a console for your radio, what do you think?
If you can't run with the big dogs "STAY UNDER THE PORCH" !!!!!
graybeard wrote:I for one think you should save that space for a outlet on you new Vintage Air AC. However you need some good tunes now and then, maybe you could get one of those cool fiberglass
Yeah, wonder if anyone makes something like that!!!
Shadow
Post by Shadow »
After Marinating On This Overnight I Have Decided Not To Drill The Dash. If I Change My Mind I Can Always Install The Radio At A Later Date. Of Course The Console Headliner Is An Option As Well. Bad News Is That After Inspecting My Core Support Yesterday I Have A Feeling Any Money I May Have Had To Spend At The Wichita Auto Swap Will Be Going Towards A Replacement. :cry:. I May As Well Replace It While The Inner Fenders Are Out. Looks Like The Winter Projects Are Stacking Up......
William-in-St George
My music is that 460 purring through a nice flowmaster. Don't drill. IMHO!
William-in-St. George
PFM-64f100
Post by PFM-64f100 »
Since my CrewCab is uncut I plan on doing the below and mounting it under the seat. I am adding in the Blue tooth option so I can play music via my Iphone. No cutting on my dash plus the price is good.
Radio/amp
http://www.amazon.com/gp/product/B0073W ... UTF8&psc=1
BT option
http://www.amazon.com/gp/product/B0047T ... UTF8&psc=1
truckster
Post by truckster »
yeah, i'd go radio-less. and you're right, that is the perfect spot for some killer pinstriping!
Oregoon
Post by Oregoon »
I'd post up my thoughts, but these guys seem to have already nailed it!
No drill, hide your system. Definitely.
Working on a '66 F100 with a '71 240 and the original three-on-the-tree...
64 f100
Post by 64 f100 »
Can't hear a radio over the cherry bombs and wind noise at speed anyway. You can make a nice plate and mount it under the dash, and still use the stock radio if you wish. Personally, I would suggest something a little more modern.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Anthony
Post by Anthony »
I say overhead console and pin stripe it!!! or at least that's what I did.. 8) I had Darin Alen of Killer Designs do mine at the Pumpkin Run Nationals outside of Cincinnati.... http://www.pinheadlounge.com/killer-D/
Image Image
Image Image
a couple better pics of the stripes laid down by Killer "D" himself...
Image Image
