Which oil pan works best w/Dakota IFS
mercman64
Post by mercman64 »
Maybe Garbz or Spark know, I'm using the IC Dakota kit w/a 1987 5.0 HO mustang engine....the motor has a rear sump.....does this work or do I have to change it to a center or front sump to clear the Dakota crossmember ?.....thanks ....oh it's a 63 short uni.....Dave
1964 Mercury Monterey Convertible
1962 F100 unibody LWB BBW "Show Truck"
1966 F100 short box "daily driver"
1963 F100 unibody "project truck"
2010 Dodge Challenger R/T
PFM-64f100
Re: Which oil pan works best w/Dakota IFS
Post by PFM-64f100 »
My 460 with Dak front end has a rear sump so I think you will be good to go. :)
LM14
Post by LM14 »
I switched my 390 to a rear sump 4x4 pan. The further back the sump is the better off you will be. Your first point of contact will probably be the rack lines for the power steering.
The dual sump (Mustang style) would be better than a mid sump pan (4x4 and vans) on a Windsor in my opinion.
If you haven't got your motor mounts built yet, I would also suggest moving the engine to the passenger side 3/4 to an inch to gain steering shaft clearance.
PFM-64f100
The other Dave (wolfee) has a 5.0 in his truck with the Dak. He used regular (80 style) mounts (he got them from Steve at IC) and didn't have a problem clearing the rack. My 460 I had to have Steve move the lines so It would clear.
You can kinda of see the motor mounts in these pictures.
mercman64
Post by mercman64 »
Thanks fellas ! The mustang motor I have has the dual sump with the big sump in the rear...GR8 !....I'll have more questions coming !...thanks for the help !......Dave
