drive shaft spins in neutral
deflaytedwayz
Post by deflaytedwayz »
Hello all. I have a '63 Uni with a 292 and T-98. The rear end blew up so I had it towed home. If I start the truck, put it in neutral and give it some gas, sometimes the drive shaft spins. If I push the clutch in, it stops. Should the drive shaft be spinning in neutral, or is there something wrong with the tranny? Any help would be greatly appreciated.
cooter
Re: drive shaft spins in neutral
Post by cooter »
nothing wrong with the tranny if the diff is blown there is nothing preventing the driveshaft from turning
deflaytedwayz
Ok, that's what I figured. Just wanted to make sure. Thanks.
