Who has limited slip?
- Blackwaterforge
Who has limited slip in a Dana 60?
How do you like it?
I would like to swap 3.54 gears and limited slip into my Dana 60 4:10 open differential.
How do you like it?
- ThinLizzy13
Re: Who has limited slip?
I have a limited slip dana 60 with 4.56 gears. I can't say too much about it cause I just putz around town or the back yard with it, but I'm pleased with it so far. Hasn't given me any trouble in rain or anything and it hasn't gotten stuck off the pavement... yet lol.
I saw some people saying on here that it can be dangerous in snow/rain/ice which I don't know too much about. I've only driven it in rain and it worked fine for me.
not currently but i had it in my d70 on my 65 towtruck.
truck was 4wd and 4.10
a lot of people confuse limited slip with lockers which effectively lock both tires in while limited slip has clutches which distribute the torque to the needed side.
there was a definite advantage in the d70, especially with tire chains while plowing snow or when going thru deep mud.
not sure what your looking for in terms of traction, i know you regularly haul heavy items in your truck.
dropping from 4.10 to 3.54 will work your engine a bit more when hauling that stuff, mostly starting out from a stop but some on uphill grades too.
i also have limited slip in my 64 rambler, it has a 3.15 rear. it handled well the few times i drove it in the winter. i also keep a couple sandbags in the trunk as well as a toolbox during the winter for added traction.
If I am not mistaken, the 3.54 gearset will not work in the high ratio case.
- Blackwaterforge
Sorry: It's the rear differential.Toyz wrote:If I am not mistaken, the 3.54 gearset will not work in the high ratio case.
- ThinLizzy13
I think the split is at 4.10... 4.56 and up will work in one and 4.10 and lower in the other. I was going to replace my 4.56's and had to get another axle with 4.10s.
4.10 up should be the same. All lower numerical ratios use different ring gear thickness to accommodate the gearset. 4.10/ 4.56, is just a matter of different shims. Good info on the pros and cons as well as the differences at DodgeRam.org. Search differential setup.
- ThinLizzy13
Well thats good to know now lolToyz wrote:4.10 up should be the same. All lower numerical ratios use different ring gear thickness to accommodate the gearset. 4.10/ 4.56, is just a matter of different shims. l
Oops, Dana lists the kit as 3.07 thru 4.10, so I am evidently wrong on the split. Sorry for the bad info. There is also some concerns on pinion clearances, but I do not recall what is what.
got a limited slip rear (4:56) in my 4x4 f250. i use the truck around the farm and for occasional runs to town. rarely notice it.
Russell,
My 66-250 has a 4:10 limited slip factory,a 3:73 was also available.Seems to do the job,no problems since I bought the truck 2001.
- Paul Merrell
I had a trac-lock in mine but it made too much noise when turning . So I removed it and put in a detroit limited slip no noise from rear. But let me tell you I have had it sideways after making a turn and shifting to third. And in the snow its fine just don't goose it or it will get loose.
Just got a good reminder on why a limited slip is a good idea this weekend. While I do not care about how I hook up at the races, I was trying to move some other cars around. My 65 w/o limited slip would spin one tire or the other on the gravel. Pulled out the '66 camper special w/ limited slip, double the traction really does help.
- Blackwaterforge
Thanks Guys!
