406 fe big block
- therealjoeshmoe
406 fe big block
anyone know anything about a 406 fe big block??
is it worth a crap or just a good boat anchor? lol
Re: 406 fe big block
The 406 was an original race motor in about '61-62. It should have the hipo heads with bigger valves but it would also have the early motor mount bolt pattern and solid lifters if I remember correctly. It was replaced by the 427 in '63.
Bore is the same as a 428 but the stroke is the same as a 390. Kind of backwards from a 410. It should be a cross bolt block if it was a later block, earlier ones were not always cross bolted.
If you can get one, get it. They bring some fairly big money.
- 6166 Junkyard Dog
AS a rule that I was reading a long time ago when I first built my 427,, 406's where not cross-bolted, UNTIL they started coming apart and a kit was offered to change that over to that until the 427's came out and ALL 427's are cross-bolted, IF somebody says it's a 427 and not cross-bolted then they are telling you a lot of 427's where offered until 1968 and the 68 motors where hyd. lifters,, my 427 is serial # from Ford
Now Cooper will try his best
- therealjoeshmoe
IM GONNA GET THE NUMBERS TONIGHT AND TRY AN FIND OUT IF I HAVE A 406 NOT SURE WHAT I HAVE REALLY
You are 100% correct as usual, Tom. The only cross bolted 406 were the end of the run until the 427 came out. They are very rare.
Joe, if it is indeed a 406, there are some collectors that will pay (in my opinion) way more than they are worth. The Galaxie guys drool over them. There is a guy in the Omaha area that buys a lot of them.
- therealjoeshmoe
well i dont think its a 406, (would have been real nice to have one) After some research online im thinking its a 63 352 but im gonna take the heads off and measure the bore and stroke after im done freeing up another 352 i got on the stand... it does have the earlier offset motor mounts
heres some pics
heres some pics
- Uncle Skip
Joey.
If you decide that isn't a 406, let me know and I'll come get it.
Uncle Skip
Uncle Skip
- Uncle Skip
Seriously, the casting number on the block C3AE-6013-Z is for a 427 top oiler. What is the casting number on the heads. Those are not 427 exhaust manifolds, or 406's either.
Strange days indeed.http://www.fordification.com/tech/casti ... Eblock.htm
- therealjoeshmoe
I THINK IT SAYS C3AE-6015-E IM PRETTY SURE ITS A 63 352
is it drilled for oil galleys for the lifters?
http://www.jalopyjournal.com/forum/thre ... 06.639669/
And I will buy a boat to use it as an anchor if you dont want it.
1966 F100 240 3speed
1968 F250 Camper Special 390 C6 with 70 Sells slide in camper
1964 Galaxie hard top. 390 dual quads
1962 Falcon soon to have 428 4 speed and straight axle.
- 6166 Junkyard Dog
IF somebody says it's a 427 and not cross-bolted then they are telling you a lie which in this case it's not a 427 since I do not see the cross bolts right above the oil pan
- therealjoeshmoe
i figured that i knew it didnt have the cross bolts.. i figure its a 352 or 390 at this point i dont care what it is lol but its mine... and its an fe, prolly a future rat rod project...
