I THINK I have a 240 in my 65 F100, I want to go with a HEI or DS ii BUT can't seem to find a listing for such, I have found listings for HEIs that say will fit 5/16 shafts but NO FOR SURE listing for the 240.
I would rather NOT pull the distributor TILL I have a replacement, will the 300 fit the 240?
Will a 300 DSii fit in a 240?
Re: Will a 300 DSii fit in a 240?
Yes the dizzy will swap over. You have impressed me if you go with the Duraspark!!!!
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
- bobenhotep
Yes it will. You will have to get a non spark valve carburetor like a carter YF if you run a duraspark. They are fairly cheap and available online. Go for it.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
School me on this.bobenhotep wrote:Yes it will. You will have to get a non spark valve carburetor like a carter YF if you run a duraspark. They are fairly cheap and available online. Go for it.
1966 F100 240 3speed
1968 F250 Camper Special 390 C6 with 70 Sells slide in camper
1964 Galaxie hard top. 390 dual quads
1962 Falcon soon to have 428 4 speed and straight axle.
I'm also interested in getting rid of my spark valve carb. Mainly because you can't find new ones and you can only rebuild the old ones so many times.
As far as using a Duraspark dizzy, I'm assuming you have to run a vacuum advance line to it...is that correct? Would you just tap a vacuum source, like the intake manifold?
Don
'66 Styleside Shortbed, I6, Original Paint Survivor
'54 Ford Mainline Tudor, 302/AOD, disc brakes
'54 Ford Club of America
http://www.1954Ford.com
- bobenhotep
The YF carb has ported vacuum on the base. You can get a manual choke carb for a 73 model, but I think it has the large base. The older ones with the small base are getting scarce. I ran the auto choke off of the exhaust manifold on my 300, and I have pictures of how to do this. The duraspark distributor will change out no problem, and I don't see why you can't use manifold vacuum, I just never have had to do so.
"The Iron Rhino"
-duraspark II/ HEI
"The Iron Rhino"
-duraspark II/ HEI
