Hoi! I've been doing a bit of reading on the Barra's, and sound like a pretty cool engine, and the power numbers are pretty impressive too.
The Barra 310T FG is the highest output version (or so I tjhink from my quick research:), and started in 2008--->present
Barra 310T FG
The high power variant of the FG's turbo I6 is in the new FPV F6. Featuring a larger turbocharger and intercooler, this is the most powerful engine (and the first to produce more than 100 hp (75 kW) per litre) manufactured in Australia. As a result, the F6's rolling acceleration from 0 km/h (0 mph) to 120 km/h (75 mph) is 4.0 seconds.
Power: 310 kW (416 hp) @ 5250 rpm
Torque: 565 N·m (417 lb·ft) @ 1950-5200 rpm
So, can any of you lads down there tell me how expensive would it be to find a decent donor engine/trans/harness/ecm?
https://en.wikipedia.org/wiki/Ford_Barra_engine
Then there is the whole shipping debacle
I expect the answer will not be what I want to hear (but in this instance, would be quite happy to be wrong).......good job I have a line on a decent 351W Roller engine
Thanks!
James
Barra DOHC I-6
Re: Barra DOHC I-6
hi, I did some research and came up with this you tube clip on barra performance.
Darren.
https://youtu.be/0LBQrMmXEIU
Darren.
Re: Barra DOHC I-6
You silly wanker, NOT THAT KIND of BARRA!! lol
- Alan Mclennan
Re: Barra DOHC I-6
I was going to say that the yellowbelly was better than the Barra, but it turns out you didn`t mean Fish !
Re: Barra DOHC I-6
Nooooooooooooooooooooooooooooo!
Not a fishy, not a wheelbarrow, AN ENGINE!! :)
quote="Alan Mclennan"] I was going to say that the yellowbelly was better than the Barra, but it turns out you didn`t mean Fish ! [/quote]
557f1 wrote:hi, I did some research and came up with this you tube clip on barra performance.
Darren.
Re: Barra DOHC I-6
What do you call a kiwi laying under a wheel barra?
a mechanic.
Maybe the best place to try would be a internet search for a Australian auto wrecker.
but be warned they like to take your money
a mechanic.
- Alan Mclennan
Re: Barra DOHC I-6
would this help as a starter..................... http://www.ebay.com.au/itm/FORD-FALCON- ... 33a80f09b3
just noticed it`s just down the road from me, about 7 k
Re: Barra DOHC I-6
Thanks! I had a quick look on ebay the other day, and looks like there are a few out there, but the 310KW versions are thin on the ground & not that cheap. And I see the Aussie $$ is about 0.93 Canadian, better than USD, but not like when Aus $ was @ 0.7
- Alan Mclennan
Re: Barra DOHC I-6
My first trip to the US our dollar was worth 50 US centsjamesdfo wrote:Thanks! I had a quick look on ebay the other day, and looks like there are a few out there, but the 310KW versions are thin on the ground & not that cheap. And I see the Aussie $$ is about 0.93 Canadian, better than USD, but not like when Aus $ was @ 0.7
Re: Barra DOHC I-6
Alan: $.50 on the dollar is pretty harsh, but that was still probably easier to take than your recent bore job, no?? (and sadly, my day is coming)
- Alan Mclennan
Re: Barra DOHC I-6
James in the end ( no pun intended ), it is worth it, most people are over it in a couple of weeks, I`ve just got to do things the hard way as usual , Hope it all goes well for you Mate!jamesdfo wrote:Alan: $.50 on the dollar is pretty harsh, but that was still probably easier to take than your recent bore job, no?? (and sadly, my day is coming)
