slick parts trivia returns- answer posted today 10-18
Re: slick parts trivia returns
ICEMAN6166 wrote:they are NOT on 65-66 2wd trucks
and from re-reading the replies this statement applies to my above hint and is actually more correct :
lineman1984 wrote:So, not on I-beam trucks...
unibody madness
Post by unibody madness »
I got lost when you said they were not on I beam trucks.... were'nt they all I beam trucks?
I am also guessing they were not on long or short f100 unis...as that's all I have spent a lot of time on
F7BIGJOB
Post by F7BIGJOB »
unibody madness wrote:I got lost when you said they were not on I beam trucks.... were'nt they all I beam trucks?
4X4 and F500 up were straight axles, I thought too where the grill was attached to the radiator support, but that would the same on all. I think I want to say I've seen these, just can not put a good finger on it..... :cussing:
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
ThinLizzy13
Post by ThinLizzy13 »
I'll take a stab....mounting brackets for the "mickeymouse" marker lights?
nope
and they are on all unibody trucks and straight axle trucks
as far as i have been using it the term i-beam refers to the twin i beam trucks 65-66 f100 and f250 2wd
unibody madness
well ok... I have no clue..., I will know what it is as soon as you unveil the mystery.
Re: slick parts trivia returns- answer posted today 10-18
not one person :cry:
go dismantle some slicks you will find strange parts
the answer to the part:
5\16x24 threaded inserts they go in the cab floor and you bolt your gas pedal to them
65-66 2wd f100 and 250 and 66 f100 4x4 do not use them as the gas pedal is suspended and has a cable to operate the linkage
be sure to tune in for part # 2, and better luck this time
F7BIGJOB
Post by F7BIGJOB »
AHA, thanks, Brian.
F7BIGJOB
-Steve
tomrooster
Post by tomrooster »
Brian, I think you have to much time on your hands, you can't be snowed it . But it's good to see somebody is keeping us thinking.. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
mercuryv8
Post by mercuryv8 »
That was fun.
Thanks iceman
chris401
Post by chris401 »
Both of my June 65 F series came with hinged pedals. I robbed a good hinged pedal from another 65 F250 at Pick & Pull in 2013. I believe my brothers 66 pedal was suspended.
