Turk eye candy update
unibody madness
Post by unibody madness »
Spoke with Brian yesterday (Iceman) and realized it had been awhile since I had posted anything about the build.
I know I need to update the build thread but I will have to get a new word program since I got a new computer and windows ten will not let me install the program I already have for xp. (really p***es me off).
Anyway since there is always something to be done, I can not say its finished, but it is close. You will have to make due with these for now
bird55
Re: Turk eye candy update
Post by bird55 »
Nicely done!
Hey now you can change your avatar! :)
Leeroy
Post by Leeroy »
It may not be finished but daaaaamn it looks good!
wow
much nicer than on my 2" phone screen
gave up nearly always broken windows many years ago for a linux system, never going back.
rbeck204
Post by rbeck204 »
John,
Looks amazing. Nicely done
61 T Bird Convertible
1953 Ford Customline 2 door
Wow ! ... That truck is P R E T T Y !
Must be fast too......
I see it slid the gas cap all the way back :rocker:
Alberta62
Post by Alberta62 »
I'm curious about the gas cap too. Are there details available?
62 Unibody shortbox, 5.0/AOD, Dakota front end, rear axle over
unibody madness
Thanks to you guys, it has helped to keep my sanity since 2009
I will be updating my build date at some point, but here is a quick pick of the filler neck under the bed rail, I just cut out the sheet metal and traced it to the new location then swapped the pieces:
Alberta62
Post by Alberta62 »
I like the idea, it looks right to me. What gas tank did you use?
MN66
Post by MN66 »
That is a thing of beauty! Well done.
1966 F250 LWB
unibody madness
I used a gas tank out of an Izusu Trooper, welded up a 1" square tubing frame,an additional 1"spacer for above, and bolted it through the frame.
I then modified the skid pan that came with it and bolted it up as well. I had to notch the top part of the frame for the fill tube, but stiffened it up with a piece of round tubing
Again thanks for the interest and comments
John
John that is one nice looking Uni! Lovin the job you did on it. TR
unibody madness
Thanks TR
Using all the neat tricks i have learned on this site and a few of my own
Having fun finding all the parts to put it back together. Two days looking for my windshield wiper arms is driving me bonkers.
ezernut9mm
Sweden
Post by ezernut9mm »
bitchin! love the cragars!
unibody madness
Thanks Ezer,
I do as well. It was a toss up between those, a set of chrome steelies by Cragar I got a deal on, or some some wheel vintiques with chrome trim. they all look great on these trucks.
ezernut9mm
Sweden
cragars look soo good on this body style. glad you picked 'em.
unibody madness
I did the first shake down run from Vallejo to Paradise Ca. everything went swell, oil pressure, temp gauge, and amp gauge all behaved, 140 miles on the yblock clickin along. About mile 90 however the steering started acting a bit loose but made it to my destination. This morning on the rack at Big O, they found steering box bolts loose, and missing one, they apparently were too short and the nylon nut did not hold. since I had the front end aligned and tourqed at a sister store, they went to ace, bought new bolts, re- torqued, inspected the entire front end and gave me the thumbs up.
ezernut9mm
Sweden
glad it ended well. lol.
The Turk looks fantastic John, a real credit to you mate! :clap:
