T98 to np435 swap..hows the speedometer gear selection...
- aj64f100390-292
Hello, I have a nice np435 sitting around and my t98 is a great transmission, even speed shifts pretty nice for what it is but Im at the lowest teeth count gear they made and Im still slow on the speedometer so I was wondering how many gear options the np435 has. And I am aware the bolt pattern is slightly different...my father has been around them.for years or was not in a long time.but says he thinks the worst thing we will incounter is only having three bolts instead of 4..or the last time we discusssed it thats what I remember him saying. Thanks guys
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now
soon:pwr asst steering
Re: T98 to np435 swap..hows the speedometer gear selection..
Hello,
Edited post.
http://www.garysgaragemahal.com/speedom ... gears.html
This site may be more helpful, showing rear axle ratio, tire size, transmission, speedo gears needed.
I can't help with the number of bolts, both my np435's had a transfer case with them.
Bradshaw
Edited post.
Bradshaw
