Looking to purchase a clutch equalizer bar from someone willing to part with one. I'm not certain to how specific these are to each application, but I have a '64 f100 with a 262 I6. Mine has suffered a catastrophic failure.
Clutch Equalizer Bar. *No longer needed
-don
'64 F100 262-I6
'64 F100 262-I6
- charliemccraney
Re: Clutch Equalizer Bar
You're probably missing the bronze bushings, too.
I had that exact same thing happen. The bushings were missing so the steel wore through and split just like that.
Lawrenceville, Ga
1961 F100 Unibody
1961 F100 Unibody
The bronze bushings were still in there, the metal just tore for some reason. A friend repaired it this evening. We were looking for a piece of steel tubing to slip over the end to reinforce it, but couldn't find the right size. We'll see how it holds up...
-don
'64 F100 262-I6
'64 F100 262-I6
- unibody madness
Re: Clutch Equalizer Bar. *No longer needed
Don, what year and motor. I have very iffy internet right now or I would look it up. Not sure if year and Motor size make a difference but PM me and be patient if you are still in need
viewtopic.php?f=32&t=18944
