alright, i replaced the fuel pump, but still does not fill the plastic filter the way i think it should, but starts and runs so we will see. I have not rebuilt the carb since the rebuild, so perhaps that is a factor. I am concerned with it running hot. My temp gauge (stock) says not, but i don't trust it, so might need to add a mechanical gauge to get legit reading. Gauge did not work connected to the sending unit in the manifold, but did get a reading from the one on the water neck. I ran today to see if the thermostat is opening, and i expected it to slurp in and start gurgling with rad cap off when it kicked in, but instead it gushed antifreeze out of the top. Perhaps i can just run without thermostat for test, it is 90 degrees out in Mooresville these days. Any advice. In any way, i see a radiator upgrade sometime in future. I think it is running the original 6 banger radiator after previous owner, upgraded to 390.
On a positive note, my son came over and helped get the hood on. Fit was ok, looks like it could use a little adjusting at the hinges, seems that it is sitting maybe 1/4 low at the edge of the cowl.
As i indicate in previous post, i had issues with the original hinge nuts in the cowl. Previous owner had used wrong bolts and a couple of them broke loose and spun out. I tried to retap for coarse bolts, and had it bolted all up, but when i went to tighten up, they stripped out. So i was certain, i was going to have to pull the hood and start all over again, but, i pulled the surround off of the fresh air vent in the kick panel, and voila, had plenty of access to at least the 2 outside hinge bolts and was able to simply add washers and nuts from the back of the cowl. Tied a wrench retrieval string to make sure i could recover the wrench and worked like a charm.
So pulled out, and washed some of the shop dust off. I pulled the badges off the hood, because i am going to have guy down the street compound and buff the truck and see where i am on paint job. There are some ruff spots, major chips in the paint so not sure what I am going to do about those. The truck was painted at some point, and my plan is to just go with it.... i kind of like the old school paint job, and just going to live with the imperfections, seems to fit the truck.
Ok, so while i continue to troubleshoot the fuel, carb, cooling issues, I think i will switch to the bed, and start the tear down and rebuild of that.
