OK this is more of general opinion question. As part of my swap to a PS steering, I have a shorter shaft from a 71. The bottom of the shaft has the top 1/2 of the rag joint attached to it.
Well, that top 1/2 "flange" of the rag joint is a little loose on my shaft. Now, it appears that the flange was not welded at ll, but instead the shaft and flange had splines. The shaft appears to have extended a little out of the bottom of the flange and then it was "swaged" or heated up and "mushroomed", so that the flange would not come off.
I am tempted to heat up the bottom the shaft and when its red hot, beat it with an appropriate sized punch to expand the end of the shaft back up and tighten the flange back up.
Does anyone see a problem here? Metal fatigue? Seems that there would be no more danger of that then would occur if I tried to weld it.
Heating it up and beating it just seems too easy somehow.....
Rag joint to steering column attachement, ? weld versus ????
- 66fordtrucknut
- 6166 Junkyard Dog
ONE PROBLEM Is the shaft at the top is going to have to be cut some since your stock wheel will fit but the horn ring will not cut about 1/4 of threads with that little stub on it
Now Cooper will try his best
