Part number for a 61 F-100 turn signal switch?
- RlCHARD CRANlUM
Can anyone confirm that the correct part number for a 61 F-100 turn signal switch is C1TF-13341-K.
Thanks...Ken
Thanks...Ken
- RlCHARD CRANlUM
Comet, its not hard to swap out your turn signal switch. its kind of tricky getting it all out inside the truck since the harness runs through the column. I would take it out and do a once through myself if I was doing this. this way you can make sure your columns bearings are good and replace them if needed as well as the lower seal. as far as the switch itself the one in my 64 fit in the column without any changes. I also made my own signal lever
if you plan doing the swap inside the pickup. youll have to remove steering wheel and horn button. as well as fish out the harness through the column housing
I am probably forgetting something here, its been a while since ive done this lol
- RlCHARD CRANlUM
Thanks Shawn. I figured it wouldn't be too hard. I just didn't know if mounting holes lined up, wires matched, etc. I also want to us the original turn lever, or one very close to it. I've had mine apart and looked at it. I just don't want to be buying parts that don't swap easily and having to return them until I find something that works. Come to think about it, I have a post uni slick column sitting around somewhere. I'll have to see if it still has the signal switch.
comet yes its a direct fit, swap ,whatever you want to call it, lol as far as wiring colors i have no idea my slick did not have the original switch inside, it had one of them fancy external mounted with a hose clamp chrome deals. I am going to say that I am sure the wiring colors will be pretty close to the same. and it wouldnt be hard to figure out which is which. I just went this way because its a new part thats about 15-20 bucks less than one for a f100, obviously one for a mustang will be cheaper since there is mass production of restoration parts for them.
- 6166 Junkyard Dog
the tag number is just a ID# Number used by Ford,, that number will then have to be converted to the correct Ford number
Now Cooper will try his best
shawns fords wrote:Comet, its not hard to swap out your turn signal switch. its kind of tricky getting it all out inside the truck since the harness runs through the column. I would take it out and do a once through myself if I was doing this. this way you can make sure your columns bearings are good and replace them if needed as well as the lower seal. as far as the switch itself the one in my 64 fit in the column without any changes. I also made my own signal lever
if you have a 4x4 or f350 or bigger the wires run outside the column and its much less hassle to deal with.
My Uni still had the original metal one in it, still works too.
