:?: can anyone tell me what this is? its mounted inside the engine compartment drives side front corner just to the right of where the headlite wires go through the sheet metal it has a small 3-prong plug that is kinda triangular shaped :?:
[/img]
not sure if i posted picture correctly here is the link to it in my alblum
http://fordtruk.com/forums/album_showpage.php?pic_id=3763&user_id=851
what is this?
- crewzinforabrewzin
what is this?
Last edited by crewzinforabrewzin on February 19, 2008, 11:30 pm, edited 1 time in total.
CONCIEVED IN DADS CHEVY BUT WILL DIE IN GPRAMPS FORD
Crewzin, when you are linking to a picture in your album, you need to use the BBC code that is under the picture. For the picture you are trying to link to, it shows this (album]3763[/album) and that is what you would use in your post like below...
[albumimg]3763[/albumimg]
Oh, and what you describe and your picture show your horn relay.
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
