83 460 in a 64 f100 4x4???????help
snow
Post by snow »
so this is my first time on here and i hope i am posting this in the right area.... i have a 83 f250 with a 460 and i was wanting to know if it is even possible to put that 460 and suspension and front rear axle and clutch and everything else ie. clutch tyranny and so on into the 64. i really like the truck and i am not looking to hot rod it just get it super cleaned up and have something for the wife and i to take crusing in the woods. and i am going to take it down to the frame anyway and would really like to do this. but this will be my first real truck project and i have know idea what i am getting into. thanks for any help..
Xcessive
Post by Xcessive »
Youll have to make a new cross member for the tranny or buy one from LMC, NPD, or who ever. there are a few parts suppliers out there who sell the Transmission crossmember.
As for the engine mounts. Same deal. Look in the parts suppliers catalogues and you can find em for a good price.
For the 64 460 engine mounts from LMC. Part number is 45-0364 for $149.95
And for the Tranny crossmember. To mount a c4 or c6 auto it's part number 45-0366 for a cost of 79.95 also from LMC.
LMC's number is 1800 LMC-TRUCK (1800 562 8782)
Hopes this helps ya out.
snow
Post by snow »
thanks for the info. i've been looking for a site like this for a while. and it's a stick so i might have to cut a little but i think that it's still do able or does that change eveything. and ya any info is good cause as of now i have no idea of what i am really doing. thank
Xcessive
Post by Xcessive »
If you're gonna keep the manual you'll have to find a bell housing for the 460 and matching clutch. In all honesty it would be easier to just swap in an automatic. BUT if you're stubborn like I am and want to keep the stick there's plenty of stuff out there for it :)
FORDBOYpete
Post by FORDBOYpete »
wave.gif Hey Snow Hi . . . . welcome.gif Welcome to Slick 60's website & forums :welcome:
IMHO, if you have the ability, skill & resources I'd tell you fabricate your own Mount & Crossmember set up rather than buy it from the vendor mentioned. I would not recommend a lot of their Items.
Manual set up you have now eliminates need for mounts at bellhousing, such as your 64 had. It also puts rear transmission X member in wrong place for 4wd set up. What vendor above will send you is for 2Wd. You can still use your 83 Bellhousing if you do your conversion correctly.
Also front X Member LMC will send has a tendency to load 61-64 chassis wrong. It creates stressing you do not want to have happen. There is a large hole in driver side chassis rail where 64 steering box sector poked thru when OEM. Their X Member is reall too light weight Mfg for the job. They have a tendency to crack & fracture over time.
If you lack time, skill, ability or resources to fabricate your own set up to work correctly, then I would strongly suggest you may be better off to be dealing with L & L Products out of Rowlet, Texas. I'm not sure L&L still has your kit, but it won't you hurt to ask.
L & L Products makes kits for "Pros" running Mud Drags & Dirt Racing. They started with FoMoCo stuff years ago and now make lots of kits for various marques & makes. L&L is a professional conversion company & members of SEMA. They're aware of damage 385 (aka 460s) will do because of torque produced. You'll find they're pricey, but I say you get what you pay for and quality + Durability with engineering behind it is worth the difference to me.
Try L & L at this link. http://www.landlproducts.com Also to get a 460 Ford running right here is where that's at. http://460ford.com These links are for the serious builder, competitor, or hobbyist. At least in my opinion they are information resources just like here as Slick 60's is for Slicks.
Uh Oh yeah, and if you're gonna do such a conversion, it saves or pays to do it right. Not doing it right can cause major grief. . . . . CIAO
Change is the Only Constant
f100matt
Post by f100matt »
-1966 Ford F100, 352, 4 speed, smoke grey, mustang buckets
-2003 Ford Ranger XL, 3.0, 5 speed
-1989 Ford F250, 460, highboy, 4x4
