getting the steering wheel off?
I just got some power steering stuff to fiddle with. I am just getting started and got the horn off. Does the steering wheel just slide off after the nut or what. It is stuck on if so, just didn't want to pry if there was a trick. Anyone with info, thx. It is a 3 tree column and not sur how it all comes apart. swapping to the floor shift column, built for PS. can't wait!
1965 F100 short bed, daily driver for 42yrs 1 million+ miles
Loosen the nut on the shaft but do not remove it.
Place the puller jack screw in the center of the nut and install the two bolts into the holes on the steering wheel.
As you tighten the puller, it may pull right off or get real tight and finally pop off. That is why you should leave the nut on the shaft!
I hate Message Boards.
- 6166 Junkyard Dog
we have a top notch puller just for this reason I don't have to worry about that nut just the nut doing it like me,
Now Cooper will try his best
cdherman wrote:And be careful. The correct bolt is 5/16 FINE (18 TPI). that may or may not be included with the puller. The soft pot metal in the steering wheel is easily misthreaded (as I have learned from personal experince).
Just an FYI, Stock steering wheels do not have a potmetal center. It is steel. It is a soft alloy so you can easily mis-thread it so do be cautious. Hawkrod
- 6166 Junkyard Dog
I agree with hawk can be easily stripped out and be sure get plenty of threads in there if not will pull threads out have done that before
the fine thread bolts that hold the fan to the water pump are the correct thread for pulling the steering wheel. i have several different lengths of these i saved just for using with my puller.
- 6166 Junkyard Dog
brian you read my mine on that
- 6166 Junkyard Dog
I would also chase the threads or maybe turn the bolt so it has a point to start deeper in the threads if it don't want to start right away
- ezernut9mm
i usually use my forehead to stop the wheel once it flys off. why didn't i think to leave the nut on?
Comes out into the cab. But the seal on the inside of the firewall (under the firewall insulation, assuming you have some) can be pretty brittle and stuck.
Remove the clamp and firewall bracket on the engine bay side and unbolt the rag joint.
I very much destroyed my old firewall insulation when removing my column. With a LOT of care, perhaps you can save yours -- the aftermarket firewall insulation looks OK, IMHO, but its not original.....
