Which Alternator????
ivaf100
Post by ivaf100 »
I'm sure this has been asked before, but I can't find the answer here. I have a '66 with a 390. I want to install a alternator with the integral regulator. Is there a alternator that bolts up to the original brackets? If so what did it come in? What about the existing regulator wiring? Any help would be greatly appreciated.
On a quiet night you can hear a Chevy rust.
Frank
rbcyouthdude
Post by rbcyouthdude »
I used a ch*** one wire. Drilled out the top hole a little larger and it fit fine.
Michael
Comet
Post by Comet »
RBC you also have to do some re-wiring. You should do a write up on that and post it in tech. Lot's of people would probably appreciate that. I've thought about doing this myself, but more important things are priority.
My Slick is rustier than your Slick! :D
BigTim
Post by BigTim »
rbcyouthdude wrote:I used a ch*** one wire. Drilled out the top hole a little larger and it fit fine.
Michael
I have done this on several Ford motors we use to pump water for irrigation. If and when the current Alt. goes out on the 460 it will get a one wire
rbcyouthdude
When I did it I got the information here
http://www.ford-trucks.com/article/idx/ ... Truck.html
hope that helps.
Michael
ivaf100
Post by ivaf100 »
Thanks, I knew someone would have some info.
Frank
Johnny Canuck
Post by Johnny Canuck »
you can use a ford internally regulated alternator.
These links should help.
I used a 2g, was simple.
http://users3.ev1.net/~bmarr/id120.htm
http://fordfuelinjection.com/index.php?p=75
http://www.bronco.com/cms/node/66
rbcyouthdude
I'd rather have a ford alt but some one gave me a new delco, that's why I went with it.
Michael
needmoretime
Post by needmoretime »
Here is the trick to convert an original over witout to many problems. The biggest advantage is removing the oem wiring and ext. reg. Cleans up the underside and looks stock!
WK
http://www.falconparts.com/One%20Wire%20Alternator.htm
:lol:
66fordtrucknut
Post by 66fordtrucknut »
Hey WK, glad you chimed in on this one, it does look nice!
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
Slick Fan
Post by Slick Fan »
That does look good, I like it. That's a much better alternative to me than putting a GM alternator on. :thumright:
Johnny Canuck
Hey Wayne thanks for showing me that AFTER I bored the holes bigger in my freshly painted inner fender for a new voltage regulator.
Now what am I gonna do to cover the holes...
...Hmmmm. Mark told me he got a "Shelby" ID tag down at the Shelby Factory..
That would keep 'em guessing :lol:
Can't you just see the ebay ad now... RARE SHELBY Big back Window 1964 MERCURY Pickup.. opening bid $50,000 :rotflmao:
needmoretime
Sorry guys,
I forgot to share that tip. The ol Falcon boys did ok and I thought I would see more of that type of thing already done. It does work and cleans the inside of the eng. room up a bit.
WK
