Page 2 of 3
Re: show me your guages
Posted: January 5, 2012, 10:05 pm
by jkimbrel65
Mike
Posted: January 6, 2012, 11:03 am
by HiBoy63
qwertyd10n wrote:Here is mine...
The two side gauges (voltmeter and oil pressure) are 2 1/16" offerings from Autometer's Traditional Chrome series... the the mini tach is a 2 5/8" unit from the same series.
Cheers,
Dion
Very nice keeps the stock look does the job. I like traditional.
Posted: January 6, 2012, 1:33 pm
by Lee's 64
BlackWater......... That is a killer dash panel. I love the LARGE vac. gauges. How hard is it to find those F800's. Great job. Do the vac. gauges work good? LEE
Posted: January 7, 2012, 12:13 am
by shocker998md
im not trying to sound like an ass, but theres 22 posts and one person put up a picture of the sweeping cluster like im looking for.
Any body else out there have pictures of there SWEEPING cluster? Or has everyone swapped to the round style.
Kenny
Posted: January 7, 2012, 10:38 am
by Blackwaterforge
Hi Lee
I bought the F-800 bezel from a site member.
It was listed in classified.
Vacuum gauge works well.
Posted: January 7, 2012, 12:36 pm
shocker998md wrote:im not trying to sound like an ass, but theres 22 posts and one person put up a picture of the sweeping cluster like im looking for.
Kenny
the sweep clusters being plastic are not very easy to change from the stock configuration or even paint if your not real good at that.plus 90% of the ones i have acquired were broken cracked or deformed from sun.
replacements cost far too much so i do believe many do change to the round metal style.
i did however change my 65 f350 from round to sweep just to be different from the rest of my trucks. since its a work truck i just sprayed it with rustoleum silver and being plastic it is what it is, painted plastic
heres one in a parts truck i have
Posted: January 7, 2012, 6:15 pm
by Toyz
Sorry,
I just like showing off my gauges
I did understand what you were asking, and noted in my post that one of the members had if fact fabricated a great looking plexiglas insert, albeit utilizing aftermarket (round) gauges, I believe.
I also considered cutting out the center raised section of the sweep panel and fitting a thin sheet of readily attained aluminum sheeting with an engine-turned finish covering the original panel, including the area originally done in the imitation machined finish.
There are sweep panels which would adapt well IMO, both after-market and OEM.
As stated, my low-rider will eventually utilize a panel which is totally blacked out until the lower smooth-surface ignition touch switch is activated; then will illuminate and perform a "sweep cycle" in the manner of the Dakota VHX, and the ProSport electronic stepper motor gauges.
Thanks for the original posting, and again sorry for the hi-jacking; the multiple responses may certainly help some of us to understand what is available and being done.
Posted: January 7, 2012, 9:53 pm
by qwertyd10n
Kenny,
Tom's got a nice new sweep style instrument bezel:
http://www.flashbackf100s.com/new_parts_page
Cheers,
Dion
[ Post made via BlackBerry ]
Posted: January 8, 2012, 12:27 am
by shocker998md
thanks for the link. Thats the flasy one that im not 100% sure if I like it. I guess Id have to see on in a truck. Anyone has some pictures of one of those installed?
Posted: January 19, 2012, 10:32 pm
by Casey 65
Posted: January 20, 2012, 11:56 am
by chris401
I never had the sweeper. Here is what I did in the 65 1/2 ton.
Posted: January 22, 2012, 11:24 pm
by 66CC
I have one of those "flashy" repro sweep clusters installed in mine. Gauges are all originals cleaned up & detailed a bit. I like the stock styling, and it looks way better than the roached out original bezel did IMO.
Posted: January 23, 2012, 7:29 am
by BigMike
Looking through your album, I found what you used to pull the old ones out.
Posted: January 23, 2012, 8:37 am
by f100jim
Here's an original bezel I got in the early 80s from the dealer.
And here's a repo I got off of ebay last year,but I painted the inner ring silver to match original.
Posted: January 23, 2012, 1:04 pm
by Casey 65
BigMike wrote:Casey 65 wrote:This is what I did with my guages.
Don't tell the women
. that's the big surprise race for the wives at Slick Stock 5!!!!
Posted: January 29, 2012, 4:21 pm
by BigMike
Installed this the other day.
Posted: January 29, 2012, 4:48 pm
by Uncle Skip
Talk about a tractor pull.....
Posted: January 29, 2012, 4:53 pm
by F7BIGJOB
Posted: February 5, 2012, 1:48 pm
by Customcab4x4
Posted: February 5, 2012, 5:33 pm
by lo6fo
Blackwaterforge wrote:
I used a chrome cluster out of a F-800 with vacuum and tach.
i love this. i stil have the same old stock single guage cluster in the center.
