Made some more progress today.
I ran the fuel lines from the tank in the cab to the engine.
I used 300 psi fuel hose with JIC push-lock connectors.
Here is the setup for the supply side,
And the return side.
To make the dip tube for the tank I used 3/8 steel brake tubing. A drilled out a compression to pipe adapter so the tube would fit through the fitting.
I got a fitting at the hose shop that goes from a compression right to a JIC. The tube goes in the bottom and the there is a feral that the JIC flare pushes against.
For the return side I had to modify the fittings coming off the engine. Dodge had a quick connect fitting there.
I cut off the bell for the quick connect and installed a 3/16 compression to 1/8 pipe. From the 1/8 pipe it goes to #4 JIC.
To go in the tank I made up a plate with a 3/8 pipe and 1/4 pipe hole. I mounted it to the top of the tank and matched two holes for the supply and return lines.
Here it is all plumbed up.
I used bulkhead fittings through the floor and frame.
Here is the engine side.
I finished off the day by remaking the mount for my hydra-boost and master cylinder. I need to put some new ends on my hoses to match up with the Dodge power steering pump. I will also have to tee into the return line to return the oil from the hydra-boost. The Ford power steering pump had two returns while the Dodge unit only has one.
Tomorrow I plan on finishing the power steering lines and then starting on the wiring.
1965 Ford F350 Crewcab, currently getting a Cummins 6bt conversion.
