Page 4 of 8
Posted: October 25, 2011, 6:57 am
by sgettin
HiBoy63 wrote:
sgettin wrote:"Transfer case seems to be stuck in 4 low."
mine was also stuck in 4x4 when i got it, turns out it was just glomed up from setting. hopefully nothing major on yours either.
looks good.
You called it. I took the side cover off of the case after draining about a cup of water out of it. I wanted to see what damage had been done rust wise. Turns out very little rust inside but as you said the shift bars were gunked up and had some condensation rust going on. Rustbuster in copoius amounts and lube and one more problem eliminated. Thanks for the heads up.
glad to hear it.
been looking at your original pillars and cab mounts looks like i rebuilt mine back pretty well correct. :)
Posted: October 29, 2011, 12:51 am
by HiBoy63
Some more done. Front clip is all back on. The $20 seat from pull and save is that came out of a 72 2wd 100 is cleaned and in Seat is a darkblue but for $20 who cares Ill use it for a few years then redo it. Truck now moves on its own who knows when the last time that happened was? A long time ago Ill bet. Put the transfer case in 2hi and removed the shifter so I could use the 2wd shifter in the 4wd truck. Ford and their silly games.
Still needs a full break job and it will be roadworthy still no snow so I may beat it yet.
Posted: November 2, 2011, 9:46 pm
by HiBoy63
http://www.youtube.com/user/jmcbrid0#p/ ... XULOLIfjR0
http://www.youtube.com/user/jmcbrid0#p/ ... XIInRvT5Vs
http://www.youtube.com/user/jmcbrid0#p/ ... dS3Gvk1Bu4
Well this is the 4x4 slicks maiden voyage under my ownership. It should be back on the road for many more years. Still have to finish up with a complete brake job, exhaust system and a title then its on the road. I doubt it will see much road time during the winter you might say the old boy is in retirement now. He deserves a nice rest after being worked hard for so many years.
Time to get back to the first project at hand the 63 F250 4x4. Its been waiting patiently.
Posted: November 2, 2011, 9:53 pm
by slickmainer
woohoo
Posted: November 2, 2011, 10:01 pm
by HiBoy63
I hear ya Gregg thats my feelings exxactly. Sorry to see that your having all the problems with your new to you slick. Motors having problems sucks.
Posted: November 2, 2011, 10:37 pm
by slickmainer
eh, im ok with it. it will give me a chance to get it done/redone so i know whats going on down the road should something else go wrong. i dont have the tools,lifts, hoist and stands to do engine work, so it's going to an old school mechanic so it's in good hands
Posted: November 14, 2011, 9:56 pm
by HiBoy63
DSCN4601 by HiBoy63-65, on Flickr
DSCN4600 by HiBoy63-65, on Flickr
DSCN4599 by HiBoy63-65, on Flickr
DSCN4598 by HiBoy63-65, on Flickr
Full brake job in progress. As soon as the 65 is parked outside it will be back to working on the 63 again. It has been neglected for too long.
Tight quarters but its all I have for now.
Posted: November 15, 2011, 8:04 am
by sgettin
cool video's. really liked seeing the maiden voyage of a truck that was previously sitting in a field somewhere for years. great work .
also, now i know what my 292 will sound like with headers on it. :)
Posted: December 8, 2011, 11:24 pm
by HiBoy63
A member on FTE that is putting a 360 into a 64 F250 4x4 was wondering it I could take some pix of the fit on the headers and the trans cross member. I thought I would post them up here to incase anyone here was interested.
Fit on the starter side it is tight. I had to make some slight adjustments to the header for it to clear the starter. Old saying bend or cut to fit. On the steering gearbox and clutch adjustment side. I had to move the clutch return spring retainer bracket and redrill a new hole for the spring and bracket to clear the headers also slight adjustment again for header to clear the steering gear box.
Re: 65 F100 4x4 parts truck turns project
Posted: December 24, 2011, 10:40 pm
by quietwyatt
Wow, You took the plunge on this one. I really like the flat black along with the black wheels and the white walls. It has a real nice look with the white walls.
Keep an eye on the starter with it being that close to the headers. It will over heat from the headers. My plan for my 65 2 wheel drive is to get rid of the headers and go back to stock manifolds. Right now my starter is going bad from the heat. A minnie starter would also help to get away from the headers.
I really like how your truck looks. Keep the pics coming.
I will get back into mine full steam after I retire. That is around 1 1/2 years yet. Then look out!!!!!!!!!!!!
Is your truck a F-100 (1/2 ton)? I see it has 5 lug wheels. Mine is a F-250 (3/4 ton) 8 lugs.
I'm going back to the original color when done. Rangoone red.
Posted: December 24, 2011, 11:12 pm
by HiBoy63
quietwyatt wrote:Wow, You took the plunge on this one. I really like the flat black along with the black wheels and the white walls. It has a real nice look with the white walls.
Thanks the flat black was just a quick rattle can job to get it down the road a year or two while work contiues on the 63. Yes this is a 1/2 ton it is the little brother to your truck. Yup the paint when finished will go back to the original geen thats on it with some sort of white top. Whole truck was green but I want to change it up a little.
Posted: January 17, 2012, 7:46 pm
by HiBoy63
65 4x4 driver takes its place outside. Just have to get it registered and exhaust and it is ready to go. Took it for a mile run up the road today and it runs great. It has new brakes and rubber lines at all the corners. I got the rearview mirrors installed, replaced all the leaking seals on the TC and front and rear ends. Took the locking hubs apart and cleaned and reinstalled. Finished up the interior trans cover and shift boots.
Cant wait to get it out on the road for a long shake down cruise. Hope our dry winter weather holds.
Posted: January 18, 2012, 12:43 am
by quietwyatt
Dang Dude!!!!!!!!! You make me wanna go work on mine now. That looks absolutely out standing for what you started with. :clap: I like the whitewalls and the caps. Never would think it would look good if I hadn't seen it. You better go lay down man. You have got to be tired going at that pace. I LIKE IT !!!!!!!!!!!!!!!!!!!!!! :notworthy: :cheers: worship.gif
Posted: January 18, 2012, 9:48 pm
by HiBoy63
Thanks Wyatt I had the help of my youngest son that helped cut labor time down on alot of stuff. The wheels and tires you see on it now are only there temporarily. I bought those from my neighbor who was parting an early 80s f150 for $40 just to get something on it to move it with. The narrow whites kind of grow on ya. Gives it kind of a late 60s early 70s retro look. I found those hubcaps at P&S in the back of a 72f100 the two front caps were in pretty bad shape so cut the centers out to fit the hub and tapped out as many dents as I could not to bad for daily driver. Final plan on wheels and tires are to find 2 more 16" 5 lug innies and go stock steel wheels with some big aggressive mud and snows not to wide but not to narrow. Repaint back to the original color caribbean turquoise color. Glad I can inspire you to get back to your 65 last I saw it it was looking pretty well on the way to being done.
Posted: January 19, 2012, 9:01 am
by sgettin
great job saving one hiboy looks nice. like wyatt says you deserve a break.
Posted: January 19, 2012, 4:23 pm
by HiBoy63
Thanks sgettin I will slow down a little now. Ive got to get the attick area of my garage insulated so that I can start to work on the 63. Before I get started on the 63 I have to teach myself to mig weld so I have a few projects lined up before I get started on the cab of the 63. I have gas welded before and mig does not look near as hard. :)
Posted: January 19, 2012, 11:32 pm
by thrush544
Wow!!! This is impressive!!! Great Job! !'m speechless.
Posted: January 21, 2012, 11:55 am
by HiBoy63
Thanks thrush544 it took a little longer than I thought it would. Started on it last spring in March took 11 months and that was hitting it pretty hard.
Posted: February 9, 2012, 11:44 pm
by pikupmn
you did a very nice job....i just got a frankenford from a guy it started out as a 65 F100 4x4 but now has a styleside box and a 63 cab with a 66 grille.....but NO RUST. do you know where i can get the front bumper brackets like you have on your truck? my frame just dead ends and i got a set of 63(?) brackets with the truck and i don't want to use the 3 bumpers thanks, jeff
Posted: February 11, 2012, 1:26 am
by HiBoy63
pikupmn wrote:you did a very nice job....i just got a frankenford from a guy it started out as a 65 F100 4x4 but now has a styleside box and a 63 cab with a 66 grille.....but NO RUST. do you know where i can get the front bumper brackets like you have on your truck? my frame just dead ends and i got a set of 63(?) brackets with the truck and i don't want to use the 3 bumpers thanks, jeff
Not sure where you might get those from. Probably need to find 64-66 4x4 or F350 64-66 being parted out and get them off of the frame. You might post a request in the parts needed forum on this web site. Maybe a member of this site will have some to sell. Try Toms Flashback 100s he is a member of this website. I dont remember his web nick.
http://www.flashbackf100s.com/
This is a link to his web page.
