http://fordtruk.com/forums/album_pic.php?pic_id=5489
http://fordtruk.com/forums/album_pic.php?pic_id=5488
http://fordtruk.com/forums/album_pic.php?pic_id=5490
1961 Ford F100 flareside
So far I've done the following:
Ignition wires, cap, plugs
New radiator
new tires, so it will roll and be driven
New brake cylinders, new master cylinder, new brake lines
New cab emergency brake cable and cleaned up brake handle and painted and lettered BRAKE (mandantory on the rolling hills)
Wiring repairs (mostly oxidized connectors) for horn, removing old generic button on the instrument panel and horn button repair and resetting of shift tube which had dropped away from steering wheel
New seal for steering column and repaint
New window parts for doors, antirattlers, and guides
Waiting on paint to do rubber parts
Seat is the original and was cleaned up and reupholstered locally
Repaint of instrument cluster and clean up of speedometer assembly including new bezels
Fixed turn signal stalk by tapping and drilling for the larger '63 stalk
Fixed friction spring for turn signal to stay in position
POR15 on back frame from cab back
Fluids and oils all around
We've got about 400 miles on it now and it runs and stops well. The 223 with the 3.7 axle is a very tourqy combination. Feels like a lot of power. The bed is off, so I'm preparing to start blasting and priming. I'm staying with the original caribbean turquoise for the final coat this year sometime.
New radiator
Astrowing wrote:Seat is the original and was cleaned up and reupholstered locally
You mean to tell me that the.. basically, pile 'o springs sitting in the cab of
my truck can actually look like that??
I'm kidding of course.. I know how to upholster, but I'm not sure if I've ever
seen a slick with the "original" seat in it!
I must say, it looks just fine.
Thanks to everyone's help and suggestions. I've got the chrome pulled off and on the way to be rechromed. I'm not really ready for it, but once I found someone ready to do it locally (and they do vintage cars and trucks), I thought I should jump on it. We have a lot of people in Houston that only do industrial jobs with other types of platings.
Got the chrome back this week and I've got it repainted and it'll look good. Last weekend, I put on new outside mirrors and I've replaced the cab mounts and radiator mounts. I got all the bolts out without doing any cutting! I also replaced the front motor mount and will do the rear engine mounts also. The rubber was all in really bad shape. I've got the cab floor primed and will paint it next.
