clutch return spring
- ezernut9mm
the one under the hood that goes on the clutch fork. anyone tell me where it goes? the shop manual is kind of vague. it shows it going forward towards the cross member, but it doesn't show where and i don't see right off where it would go. any help?
- ezernut9mm
oh, and that big sob under the dash. any hints on hooking that bad boy up? i can tell where it goes, but i'm not falling for the "let pliers slip and take a chunk of my forehead out with them" trick. any advice on that one?
- Pro-Street/StateTk
ezernut9mm
I've messed with a lot of these old trucks, 65--79 and where that (Spring) hooks may
Vary some have been hooked to driver side engine Stand , or in one of the holes
below the stand ,in the crossmember ! Hope this helps . Sorry about it being two
answers this is what I have came up with ,both seem to work good !
Wally Womack
Wally Womack
Pro-Streeting Ford Truck's with all stock Ford parts since the mid 90's
the one on the fork hooks to either a frame bracket with a little hole or in the under engine crossmember. will go see.
the other one under the dash is best attached before installing the pedals, if you pull the pedal all the way up it should be easy to get onto the notch on the bracket.
came off easy and did not go flying across the yard.
- ezernut9mm
pro street, i currently have it hooked to the rear of the front cross member where there is a gusset or something with a little notch. doesn't look right, but has some tension and is working so i'll stay with it for now.
brian, any pics would help, but don't go laying in all that mud on my account. lol
now you tell me (about the big spring). i may just have to start over. that thing has an ungodly amount of tension on it.
- ezernut9mm
thanks for the pics brian, mine doesn't have one, i wonder why? lol. i have it hooked to a hole in the crossmember and seems to work fine there.
