kstones63 project
Re: kstones63 project
The Mark VIII wiring was the same way, wires going everywhere. That is why I built the cover over the intake, just to help hide the wires. I took the original loom apart just so I could move the wires around where I wanted them to go but I still had to lengthen and shorten some of the wires. I just don't have any pics of the looms of wires that are on top of the trans and going all over. They are bundled together but there is a lot of looms.
Kevin
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
Actually I looked back in some of the earlier pictures of fitting the engine and theres a half decent picture of the wire looms going back over the tranny .
I have my work cut out for me . I was actually considering making a set of stainless false inner fenders to hide all of the junk under between the stock inner fenders and the stainless ones .
I ran all of my wires up next to the firewall and into the cab from under the fender apron. I also put the a/c and heater hoses under there as well. I didn't build a protection wall but I am thinking that it would be a good idea in case a tire ever comes apart. That would be a mess.
Kevin
Kevin
kstones63
63 F100
63 F100
Utilizing the COP as on the Gen II Marks also helps clean everything up. I'm thinking either a SDS or PMS system such as for the 32 valve Mustangs would be well worth the cost for the ability to eliminate un-needed circuits, let alone the tuneability advantages
Paul.
Paul.
Toyz wrote:Utilizing the COP as on the Gen II Marks also helps clean everything up. I'm thinking either a SDS or PMS system such as for the 32 valve Mustangs would be well worth the cost for the ability to eliminate un-needed circuits, let alone the tuneability advantages
Paul.
That is why I converted to the COP. It is a lot cleaner thatn the coil packs.
What is the SMS & PMS system? I'm not familiar them. Mine is OBD1 so it needs a prom chip or the Moates Quarterhorse chip that is programable. I think that I am going to use the prom chip just because it is easier and I don't think that I want to learn the binery editing needed for the Moates chip.
Kevin
kstones63
63 F100
63 F100
I just looked up the Anderson Ford PMS system for the 32 valve and there is no listing. I have the original developer's email addy somewhere; I will check to see if he supports the 32 valve.
The SDS (Simple Digital Systems) is my first choice for a standalone system, and the 32 valve is supported thru Western Motorsports- wmsracing.com. The big disadvantage here, other than the cost, is the lack of electronic transmission controls, requiring the purchase of a controller such as the Baumanometer.
Since you already have a workable system, you would probably be better served with a PROM. Starting from scratch, I would highly recommend the SDS. The inexpensive option would be to do as you did, only utilize the Gen II (97/98) OBD-II system, then buy a hand-held, or have a reputable tuner set it up.
The go-to guy for EEC-4 used to be Jerry Wrobeleski, a former Ford engineer. He was involved in the original twin supercharged Mark VIII that Lincoln ran at Bonneville. I have not heard from/about him in a number of years.
Dennis Reinhardt, at Reinhardt Automotive in Jacksonville, FL., also is a reputable source for EEC-4 issues, especially on the 32 valve applications.
I googled the SDS system. It looks like a pretty good way to go but I'm not really looking for a real performance tunable program at this time. That might change at a later date, who knows. I'm mainly looking for a chip to get the codes out of the computer so I can hook the check engine light back up. I also want a little bit more performance just because.
I talked to Dennis Reinhart about a chip and I am probably going to have him build it for me. I was hoping to find somebody local to make it just in case I miss something that needs to be deleted. This way it is easier to get it redone. I haven't had any luck finding someone local so it is probably going to Reinhart.
Kevin
Kevin
kstones63
63 F100
63 F100
BEAUTIFUL build,keeps the pics coming. Great color. Tony
where did you get the tail light filler kit form? i like that idea
I bought one piece of aluminum and the rest was built out of material from my garage. This is what I think about when I can't sleep at 2:00 in the morning. It really isn't that hard to build but I have a small mill in my garage so that helped for cutting the slots. I am sure that there are other ways to cut them but that was the easiest for me. If you want more pics, send me your email address and I can send you more.cnb wrote:where did you get the tail light filler kit form? i like that idea
I think that the hardest part about this was mounting it in that small opening. I had to cut a hole in the side of the stake pocket to mount it and then make a plate to cover it. The cap is a push thru cap so you don't have to get your hand in that small opening. It came from Hagans Street Rods.
Kevin
kstones63
63 F100
63 F100
