Guys.
Jim here in Houston may have already asked this question, but I haven't seen it or any answers.
He's looking at a set of heads advertised as 427's and the casting number on them is C4AE-6049-H. I don't think its a 427 but I could be wrong (I am on a regular basis) .
In all my books, the only "C4" 427 casting number I can find is a C4AE-F and its listed as a high riser head.
I looked in the interchange manual and it doesn't list the "H" part number for anything but a 390 police interceptor, AE being a Ford passenger car.
Any comments or help?
U@ss
427 cylinder head casting numbers
- Uncle Skip
Skip
Hawkrod would know about the numbers. A lot of the published info on part numbers is incorrect or incomplete.
Unless someone is restoring a 427 to original condition, I would sugest the after market Edelbrock heads. By the time I got valves, springs ,keepers ,seals, and had the machine work and seats installed I could have had a set of aluminum heads. JMO
- 6166 Junkyard Dog
Try these numbers on 427 heads,
C3AE-6090 D EARLY 63 LOW RISER TO 3/15/63
C3AE-6090 G LATE 63 LOW RISER FROM 3/15/63
C3AE 6090 H LATE 63 LOW RISER FROM 3/15/63
C3AE 6090 J 64-65 LOW RISER
C3AE 6090 K 63 HIGH RISER
C4AE 6090 F 64 HIGH RISER
C5AE 6090 F or R 65-67 MEDIUM RISER
C7OE 6090 K TUNNEL-PORT
C8AX TUNNELL-PORT
These next 3 numbers are 68 failane/montego to 2/1/68
C8AE N C8AE 6090 J
C8WE 6090 A
1968 HEADS ALSO HAD 14 BOLT HOLES SINCE ALSO USED IN Mustangs and Cougars
C8AX TUNNELL-PORT
C8AE N C8AE 6090 J
C8WE 6090 A
Now Cooper will try his best
- 6166 Junkyard Dog
Jim, I looked through sevearl Ford books & found nothing Interchange Books & what high performance on the FE Series I have, still nothing
