help pulling rear axle
Posted: July 20, 2009, 9:48 am
I looked up my axle code on fordification.com.
http://www.fordification.com/rearends-ford01.htm
the tag reads:
WBG-F2
3.89 4CA 301
It looks to be a 9" rear end. and as far as I know it's the original one from the factory.
Here are pictures of how the axle sits:
[albumimg]6197[/albumimg]
[albumimg]6202[/albumimg]
[albumimg]6201[/albumimg]
The passenger side axle slid out of the housing with minimal effort, I made a make-shift slide hammer with a 3 pound sledge tied to a 3 foot cable. It took all of six swings to break out that side and the bearing and the Axle seem to be in good condition. There was no rust on the inside of the housing, no binding on the differential, everything is in working order.
[albumimg]6199[/albumimg]
The driver's side axle was a different story. I hooked up the cable and swung about a dozen times, and then I swung harder. I swung so hard I broke my sledge hammer head right off the handle. I grabbed a small single hand weight lifting bar (maybe a foot long) and strapped 6lbs on one end of it and attached it to the cable, I swung until my arms had had enough. I ended up taking it over to my brother’s house and chained it up between two very stout tree trunks and proceeded to try to yank it out with a cable “come-a-long”. We put a lot of force on the come-a -long, so much so, I was afraid we were going to break it, with it strapped up to the trees, we heated up the housing where the bearing seats in and beat on it with a sledge hammer. No dice. Nothing moved.
I don’t know what I’m doing wrong. As far as I know once those 4 nuts are off the retaining plate, the axle should come out with a slide hammer. Are there any retaining clips or anything that I could be overlooking? All the information I’ve read says a slide hammer should be adequate for pulling an axle. I don’t really want to take it to a shop, and the only other thing I can think of is tying it to a tree, and the other end to my daily driver and pulling it that way, but I don’t want to break anything or have an axle come flying into a back window.
I’m out of ideas and I’m open for suggestions.
the tag reads:
WBG-F2
3.89 4CA 301
