66 F250 Steering Wheel Removal
jefflovesf250s
Post by jefflovesf250s »
All: Up here in the cold north where heated garage space is scarce, small inside jobs keeps the restoration going in the winter. I want to remove my steering wheel and horn ring for restoration with an Eastwood kit.
However, it is not obvious, to me, as how to remove the horn ring so I can get to the nut holding the wheel to the column. Any suggestions/pointers to assist with damage-free removal will be gratefully received. I'm sure there is a ton of experience out there in cyber space. Thanks. Jeff
Slick Fan
Post by Slick Fan »
Welcome to the site! :hello:
1st, unplug your horn under the hood.
Then push the center of the horn ring with your palm & simultaneously turn 1/4 turn counter-clockwise. It should pop off in your hand.
Make sure you use a steering wheel puller to remove the wheel, so you don't crack it bu yanking on it.
