I want to clean and detail my C6 before it goes in the chassis and put new seals in it, etc....
Anybody know a good way to get the aluminum housing clean? Can / should the trans be painted?
How to clean a C6 trans?
- Gary Seymour
Gary,
There's a cleaner that's used on commerical equipment that works well.
Don't know the name of it but its stout and works great on aluminum.
We used it on construction equipment and it would remove the oxidized paint layer in about 10 minutes.
Might check with a local truck or farm / construction dealer about getting some.
i used some of that gunk foamy degreaser, then used a pressure washer, was spotless, i made sure i didnt get any of the openings and put the new seals in when i was done, after installed i filled with fliud, ran it for 10 min in park, then drained it all and put new fluid back in,,
________
Honda Freed specifications
________
- Gary Seymour
Ive tried simple green, POR marine clean, Dawn dish soap, gas, and kerosene.
K works well but I swear by Autozone cheap brake clean.
You can degrease a trans with about 6 cans. NOTHING works better
no after shot of this but 2 hours and a few cans of brake clean had it completely degreased. Sweet cross member no?
