transmission question
Brion71
Post by Brion71 »
ok guys someone has to be able to help me out, i am just about to get a new transmission. I have a 351 w sitting on the frame. The :?: is c4 or c6. Im not sure which one will work or which one is stronger. So I need help. Thanks
Brion.
_______________
66 Ford F-100 Custom Cab SWB Flareside
89 Ford Bronco XLT 4x4
jakdad
Post by jakdad »
You can use either one depending on your needs. If you do a lot of towing etc. get the small block C-6. You will lose more H.P. through the larger diameter clutches. The C-4 is good for almost anything else.
Jim
MadMaxetc
Post by MadMaxetc »
what he said.
The C4 has an 11% loss and the C6 has about a 22% loss. The C4 is good for everyday and some light towing an hauling, but the C6 is good for heavy work and lots of power.
You can tell just by looking at them. The C4 is dwarfed by the C6.
My Build Thread
64 f100
Post by 64 f100 »
With gas being what it is, you might consider an AOD.. A C4 can be built to be nearly as strong as a C6. Overall, the C6 is a much stronger tranny stock, and stall is about 1600 on the C6, from what I've been told.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Johnny Canuck
Post by Johnny Canuck »
my favourite truck of all time was my 78 F100 with a 302 and a C4. Only thing i did not like about that truck was the weakness of the C4.
I would go for a C6 any time over a stock C4, but as these fine gents have stated, a c4 can be built much stonger than factory, as can an AOD, which is basically a C4 with an overdrive gear, as I understand it.
